Seat Rail Problem
Old Jan 4, 2004 | 10:07 AM
D16OnTop's Avatar
Default Seat Rail Problem
The Car: 2000 Ex
The Problem: I moved my seat to the far back position and now it wont come back up. Is it off the rail of jamed? If so how do you fix it?
Old Jan 4, 2004 | 10:31 AM
dmotoguy's Avatar
Default Re: Seat Rail Problem (D16OnTop)
you could start by unbolting the seat and checking it out.. you have to know the problem before you can fix it.
Old Jan 4, 2004 | 10:48 AM
1 point 6's Avatar
Down Since Day 1
Community Builder
Community Influencer
Default Re: Seat Rail Problem (dmotoguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dmotoguy &raquo;</TD></TR><TR><TD CLASS="quote">you could start by unbolting the seat and checking it out.. you have to know the problem before you can fix it.</TD></TR></TABLE>
True that, but probably the seat adjust wiring came off. Its just 4 12mm bolts to take the seat out.
Old Jan 4, 2004 | 11:10 AM
D16OnTop's Avatar
ill take the seat off and see what I can find
Old Jan 4, 2004 | 11:33 AM
D16OnTop's Avatar
Default Re: Seat Rail Problem (1 point 6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 point 6 &raquo;</TD></TR><TR><TD CLASS="quote">True that, but probably the seat adjust wiring came off. Its just 4 12mm bolts to take the seat out.</TD></TR></TABLE>
The adjusting wire is working but the seat is jammed so far back i cant get a wrench at at the back right bolt
Old Jan 4, 2004 | 12:19 PM
D16OnTop's Avatar
ill check
94HybridEX
Honda Civic (2001 - 2005)
47
Nov 12, 2012 06:47 AM
tr7driver
Jan 29, 2008 05:54 AM
DefendentOfHate
Jul 2, 2005 05:22 PM
Andrew 825SM
11
Mar 17, 2004 10:46 AM
