----> Finished Swap Now Car Will Not Start <----
Old Jan 4, 2004 | 01:37 AM
nevin's Avatar
Default ----> Finished Swap Now Car Will Not Start <----
Its not getting fuel. I took off the line coming off the fuel rail and cranked the motor and nothing came out. I cannot hear the pump priming. Im guessing its an electrical problem, I checked all the fuses. Don't know what to look for next.
Any help would be great, Thanks.
Old Jan 4, 2004 | 11:38 AM
nevin's Avatar
Old Jan 4, 2004 | 12:35 PM
blah13's Avatar
Default Re: (nevin)
Do you hear the main relay click? Turn to ignition, it should click, then a low hum for about 2-3 sec, then when the check engine light turns off, another click. If your not hearing this then I'd check that.
Edit : what engine into what car?
Old Jan 5, 2004 | 02:55 AM
nevin's Avatar
Default Re: (blah13)
yeah that was it. Forgot the harness ground on the thermostat housing which fucked the relay. thx
JdmRex805
19
Nov 20, 2014 05:23 PM
olds1983
Honda Civic (2001 - 2005)
Dec 2, 2012 06:34 PM
vtec8200
Jul 16, 2012 03:16 PM
MJPana
Jul 30, 2006 09:27 AM
Jonmon
Jun 17, 2005 03:41 PM
