Type-r piston
I will buy an engine from a guy that put P073-a0 piston in his b16a first gen
and he told me that give higher compression: i am sure that it's false it suppose to drop the compression ratio to 9.7:1...
Wath are the disavatage to run these piston in a b16a and what the advantage...?
ok: lower comp/rat = turbo setup
higher = N/A
But is there someting to know about these piston that could change my idea to buy this engine.
Thanks
Modified by titerex at 2:52 PM 1/4/2004
higher = N/A
Thanks
type r pistons in teh b16a will RAISE the compression to about 11:1. If u gonna turbo then u don't want this engine. Advantage = higher compression = faster
Disadvantage = higher octane gas, more heat, etc
If u gonna turbo, go for the LS
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF8_SiR »</TD></TR><TR><TD CLASS="quote">type r pistons in teh b16a will RAISE the compression to about 11:1. If u gonna turbo then u don't want this engine. Advantage = higher compression = faster
If u gonna turbo, go for the LS</TD></TR></TABLE>
wrong itr pistons have a much smaller dome than b16 pistons
puting itr pistons in a b16 will lower cr not raise it
Ah ****....
my bad....guess it's back to more research
so if one wanted to raise compression for a b16a, which type of OEM pistons would be applicable?
Also why do the magazines always talk about ITR pistons raising compression?
