I wanna' get 200whp, what else do I need...
Old Jan 3, 2004 | 09:30 AM
joey1320's Avatar
Default I wanna' get 200whp, what else do I need...
This is my setup:
ZC motor
SRP 9:5.1 pistons
Eagle Rods
14B turbo
HF mani
johnnyracecar.com intercooler
2.5" piping/no cat.
450cc DSM injectors
AFC hack
FPR set @ 40psi's.
Right now is only boosting the stock amount of psi's. Which is somewhere between 7-8(right?). I haven't been to the dyno, but what else do you guys think I need?
Any advice will be appreciated...
Thanks!!!
Old Jan 3, 2004 | 09:33 AM
bigwig's Avatar
10psi or so should give you the numbers you want
Old Jan 3, 2004 | 09:37 AM
joey1320's Avatar
Default Re: (bigwig)
up to how many psi can i push with the hack??? isn't it around 10-11 before the ecu starts throwing codes...
Old Jan 3, 2004 | 10:46 AM
97ITR60's Avatar
Default Re: (joey1320)
get a hondata and get rid of the hack.
Old Jan 3, 2004 | 11:42 AM
bigwig's Avatar
hondata for 200whp, thats a little overboard dont you think?
I would suggest TurboEdit the following. Make a program with turboedit to deal with your timing and richen up your basemap. Then to fine tune use the AFC. That way you can tune while you are in your car, no need for a wideband, chipburner and such. And its still very affordable.
Old Jan 3, 2004 | 03:24 PM
Bailhatch's Avatar
seems like your ready to go. If you do need to run more than 11-12 psi to hit your goal, Just turn up the fuel pressure a few psi and lean out the afc a few %. Then you can run 13> psi on the hack with no cel.
JDM_Risa
Aug 20, 2005 03:35 PM
94integragsr
Jul 23, 2005 08:13 AM
swlabhot
Jun 27, 2005 12:56 PM
Turbo D' Sol
Feb 11, 2004 10:28 AM
D@nnY
Dec 29, 2003 11:38 PM
