JDM 98 Spec Radiator.
Hi,
The new year didn't start very well for me......
when i opened the garge door i found a small puddle of coolant under my car.......
i checked the overflow reservoir bottle and the level was down.....
i jacked her up and from what i could see the radiator cracked from the lefthand bottom side.............
Here in Malta we can't find quality replacement radiators so i will have to order one......
i am undecided between the koyo, fluidyne or C&R ......
i still have another problem guys................
my car is a JDM ITR with AC, will i have fitting issues with these USDM radiators cause they were designed to fit your car with the different front ends please?
Maybe somebody with an aftermarket radiator, ac, and jdm conversion can help me please................
Rgds,
Rgds,
that has put my mind at rest as regards the mounting points.....
but what about the fact that it has AC ?
Will i need to install both stock fans on my new radiator?
i noticed that the C&R radiators come with one fan..
rgds,
rgds,
Thanks a lot !!
will it be a problem if i run only one fan instead of two cause my car has ac pls?
what wiring alterations need to be made?
rgds,
rgds,
But what about the fans please?
If i buy the Fluidyne and fit only one fan (i read that the stock one will fit no problem), will i have problems cause i won't be fitting the AC fan as well ?
rgds,
rgds,
JaydMiKeY
Aug 20, 2005 01:29 PM
guyuenvy
Jun 20, 2001 12:24 AM
