how would a MSD ignition improve my idle on a turbo honda (ZC)
Old Jan 3, 2004 | 03:33 AM
djnikko's Avatar
Default how would a MSD ignition improve my idle on a turbo honda (ZC)
as the title says....
thanks in advance (or retard)
Old Jan 3, 2004 | 05:02 AM
turbotypeR@SPEC's Avatar
25 Year Member
Default Re: how would a MSD ignition improve my idle on a turbo honda (djnikko)
i don't think the idle will change
Old Jan 3, 2004 | 06:05 AM
djnikko's Avatar
Default Re: how would a MSD ignition improve my idle on a turbo honda (turbotypeR)
will the acceleration be more responsive/smoother??
Old Jan 3, 2004 | 06:57 AM
D-Man's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djnikko &raquo;</TD></TR><TR><TD CLASS="quote">will the acceleration be more responsive/smoother??</TD></TR></TABLE>
Yes,I think so..The multi-sparking will clean up the idle too because instead of firing one spark every rev like stock it throws 3 or more over a 20 degrees crank duration every rev while under 3000-3300rpm.
Old Jan 13, 2004 | 11:54 PM
djnikko's Avatar
Default Re: how would a MSD ignition improve my idle on a turbo honda (D-Man)
will a MSD ignition help me remove flat spots in the rev range? around 3800-4300rpm
Old Jan 14, 2004 | 03:24 AM
RGAZ's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djnikko &raquo;</TD></TR><TR><TD CLASS="quote">will a MSD ignition help me remove flat spots in the rev range? around 3800-4300rpm</TD></TR></TABLE>
not unless its ignition related not fuel. What ecu are you running on the ZC? The fuel curves from the Si ECU will always have a flat spot. Try a ZC ecu or a Zdyne with ZC tune.
BTW-Idle should be smoother, quicker starts, better mileage.
Randy
jdmturbo1127
Apr 3, 2007 11:07 AM
Jockobo
Jun 30, 2004 01:46 PM
VDoP-B18C1
May 19, 2004 05:59 PM
IloveNewt
Apr 23, 2004 02:26 PM
djnikko
Mar 3, 2004 11:49 PM
