p2p ecu
Old Jan 3, 2004 | 02:15 AM
b1698civicex's Avatar
Default p2p ecu
I have a 98civic ex but with a b16sir2. I am currently running the b16 with my old d16 sohc wiring harness and ecu b/c the b16 ecu and harness were causing problems. well anyways the setup is fine and all but my specs are still d16 specs, can i scan my p2p chip to maybe at least b16 specs or maybe even type R specs? thank you.
Old Jan 3, 2004 | 09:11 AM
lilredhatch's Avatar
Default Re: p2p ecu (b1698civicex)
Find a good B16 ecu that u know works fine. I would definetly do that before i started messing with an OBD2 ecu. Just my opinion...
Old Jan 3, 2004 | 12:12 PM
Default Re: p2p ecu (lilredhatch)
what about a obd2 to obd1 conversion using a type R or gsr ecu? Has anybody ever heard anything about the weapon R obd2 to obd1 conversion or the skunk2 conversion kit? how good will this work?
Old Jan 3, 2004 | 01:34 PM
All conversion harnesses are well worth it. OBD2 is so restictive. I use to have one of the conversion harnesses, for me and from what I've heard from others is that your idle will lope a little. Still well worth it to go OBD1 anyone will tell you that...
Joeski99Si
Sep 4, 2008 10:18 AM
im a monster hehe
Apr 22, 2006 10:08 AM
B18 CYA
Apr 28, 2004 09:58 AM
Gmedalion
Jul 10, 2002 07:56 AM
