Fuel Pumps.... in tank 255 walbro/holley.... should i ALSO use an inline?
Old Jan 2, 2004 | 10:30 PM
Erik_Pb_Foot's Avatar
New User
Default Fuel Pumps.... in tank 255 walbro/holley.... should i ALSO use an inline?
I've got a new holley/walbro 255 pump in my tank but i also have an msd inline pump sitting around i was going to install inline back near the tank somewhere. anyway, i want my fuel system to be ready for when i get my bigger turbo here in the next 6-12 months and i want to do everything at once now so my question is..... is their any need for an additional pump if i've got the 255 already? or is the saying "the more the merrier" true here?
i'm running 25psi with this setup, will be bumping that up to about 30 with an sc63 in the future......
-Erik <--- thanks guys
Old Jan 3, 2004 | 04:16 AM
New User
Default Re: Fuel Pumps.... in tank 255 walbro/holley.... should i ALSO use an inline? (Erik_Pb_Foot)
nobody?
Old Jan 3, 2004 | 05:03 AM
turbotypeR@SPEC's Avatar
25 Year Member
i have seen around 500 whp on a walbro 255 pump with stock lines.don't change it
Old Jan 3, 2004 | 05:40 AM
Couto's Avatar
Default Re: Fuel Pumps.... in tank 255 walbro/holley.... should i ALSO use an inline? (turbotypeR)
Well good comments that's what I want to know about this fuel pump so I think is good for my h22a turbo a 14psi
COUTO
Old Jan 3, 2004 | 03:13 PM
New User
Default Re: Fuel Pumps.... in tank 255 walbro/holley.... should i ALSO use an inline? (Couto)
thanks man
Old Jan 5, 2004 | 10:13 PM
NVturbo's Avatar
O.G. triple O.G.
Get rid of that inline fuel pump and get yourself some larger injectors and a air/fuel controller...
Old Jan 10, 2004 | 04:25 PM
New User
Default Re: Fuel Pumps.... in tank 255 walbro/holley.... should i ALSO use an inline? (NVturbo)
car isn't yet on the road/track...
i've got a dfi gen 7 standalone and the injectors aren't going to be big enough but i can work on that later.
the reason i was inquiring on an additional fuel pump would be as a safety/backup so if for any reason my walbro 255 didn't hold up or couldn't provide enough fuel, the inline msd would pick up the slack.
Old Jan 10, 2004 | 04:42 PM
E-Rok's Avatar
EPIC TUNING
255 is fine for atleast 400whp IMO.
Old Jan 10, 2004 | 04:54 PM
Full-Race Henry's Avatar
Default Re: Fuel Pumps.... in tank 255 walbro/holley.... should i ALSO use an inline? (rewsnaeht)
I did 420whp on a walbro gss341 which is a 255lph non HP.
Old Jan 10, 2004 | 05:29 PM
jinxproof99's Avatar
New User
Default Re: Fuel Pumps.... in tank 255 walbro/holley.... should i ALSO use an inline? (Full-Race Henry)
stock lines and a walbro255 are great for up to 500 to the wheels. if you are planning on running close to 30 lbs of boost on a sc63 you are going to make alot more power than that. say you are around 600-650. you should consider 8an feed lines and an inline pump ala aeromotive, paxton, weldon, etc.......
Old Jan 10, 2004 | 05:57 PM
SJP0tato's Avatar
If you're really worried about getting every last bit out of your Walbro, don't use the stock honda fuel-pump wires. Set it up with a relay and some decent gauge wiring (gauge 5-8 will probably be fine) off the battery (MAKE SURE to run an inline fuse close to the battery). This helps because the walbro draws more amps than the stock pump (and more than the stock wires can fully provide). This also eliminates the "turn signal sound change" in the fuel pump's operation.
Hope that helps,
Ryan P.
Old Jan 11, 2004 | 06:51 AM
New User
thanks for the replies guys.
I've replaced my power wires with 12 gauge (better than stock, not too overkill) that come from the relay on my accel dfi harness...
i guess i'm gonna put this MSD i have inline for now just b/c I have it but it sounds like I'm going to need more pump in the future....
92redhatch
May 27, 2010 04:50 AM
viet_boi_racin
Feb 3, 2008 09:34 AM
envee
Feb 24, 2007 06:08 PM
hovic
Mar 12, 2006 03:43 PM
boostagsr17
May 20, 2004 12:59 PM
