How do i reset a ecu?
Old Jan 2, 2004 | 09:34 PM
trooper0641's Avatar
Default How do i reset a ecu?
Old Jan 2, 2004 | 09:44 PM
thenick's Avatar
Default Re: How do i reset a ecu? (trooper0641)
disconnect the battery for a couple of minutes
OR
remove the back up fuse for like 10 seconds
Old Jan 2, 2004 | 09:49 PM
Default Re: How do i reset a ecu? (ixiblindixi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ixiblindixi &raquo;</TD></TR><TR><TD CLASS="quote">disconnect the battery for a couple of minutes
OR
remove the back up fuse for like 10 seconds</TD></TR></TABLE>
Any reseting the ecu is good for...?
Old Jan 2, 2004 | 09:56 PM
life sux die's Avatar
RIP 1032
OR
OR
you could just disconnect your ECU, that way you won't have to reprogram your stereo.
Old Jan 2, 2004 | 10:09 PM
Unit 01's Avatar
1.) Drive your car
2.) Turn off your car
3.) Pull out the blue 7.5A (or 15A fuse, can't remember. been a while since I did this) fuse from your underhood fuse box for 1 min -- it's your ECU fuse (refer to the fuse diagram for exact location)
4.) Plug the fuse back
5.) Restart your car and idle for 10 minutes
6.) Restart your car and your car should be running with the new reset configuration
luvinmyGSR
Jun 12, 2006 10:44 PM
gutterslide
Jun 3, 2005 09:44 PM
Pearlude
Nov 14, 2004 06:41 PM
sleepyhamsterlx
Nov 26, 2003 06:52 PM
skimb37
May 26, 2003 10:23 AM
