Heading to the dyno tommorow, any predictions just installed some parts
Well I spent the good part of the day installing Hytech header, b-pipe, and muffler, and AEBS intake maniflod, along with PRO-Fab IM gasket. Already had J's intake, and 18 deg. timming.
Last time I put down almost 161hp and 116tq
Are you just doing a baseline or are you tuning? What fuel management/ecu are you using?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rhetoric »</TD></TR><TR><TD CLASS="quote">Are you just doing a baseline or are you tuning? What fuel management/ecu are you using?</TD></TR></TABLE>
You are definitely going to need fuel tuning. I removed the JDM 4-1 header in favor of the HyTech and the car is noticeably slower. I have Hondata, and as soon as possible, the car is going to C_A_T for tuning. I suspect that my car is running appreciably leaner with the better flowing header. If you don't have any fuel management system other than stock, I highly recommend that you get one.
I gained 17 hp (bosch dyno, crank hp) bolting on the Hytech system, and another 6 from tuning. At 5000RPM it gained 6 hp bolting it on, and another 9 hp from tuning by lowering VTEC.
So my guess is 176-178whp without tuning.
HP predications thread are stupid..but i guess you should do no better than 169 whp. just dyno it and place before and after results
what do we look like dynojets
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrmaninny »</TD></TR><TR><TD CLASS="quote">HP predications thread are stupid..but i guess you should do no better than 169 whp. just dyno it and place before and after results
Stupid is as stupid does
168 & 123
</TD></TR></TABLE>Stupid is as stupid does
168 & 123
baselined 161/116..
Austin on here has mugen intake, hytech header/cat/exhaust and Hondata with 290 injectors and hes doing just over 180whp with alot of tuning. i would say 176-178 with a good 128-130 torque.
but who cares what ur peak numbers are.. its all about your midrange power.
TylerC161
Nov 17, 2007 06:38 AM
