how to tell which is + and what is - on tweeters
Old Jan 2, 2004 | 07:22 PM
stock97's Avatar
Default how to tell which is + and what is - on tweeters
i bought some infinity kappa 6x8's (ford sucks) some time ago and it would seem that infinity uses suck *** glue because already two of the tweeters' glue has failed breaking the wires on the tweeter.
soo... i was gonna put them back on with some 2-part epoxy but i don't know which is positive and which is negitive
any help would be greatly appriciated
Old Jan 3, 2004 | 12:33 AM
nsxxtreme's Avatar
Default Re: how to tell which is + and what is - on tweeters (stock97)
There really is no + or - it is just used so you keep the correct phase. I would check with the manufacturer because there is no other way to tell.
Old Jan 3, 2004 | 12:36 AM
GSteg's Avatar
now this is one of the very few cases where a AA battery wouldn't be useful. lol.
I find it that most people can not tell a differences if the polarity is switched, especially with the tweeters. chances are, as long as the polarity on both sides are the sub, you won't hear any difference. Human ears sucks.
Old Jan 3, 2004 | 12:50 AM
nsxxtreme's Avatar
Default Re: (GSteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSteg &raquo;</TD></TR><TR><TD CLASS="quote">now this is one of the very few cases where a AA battery wouldn't be useful. lol.</TD></TR></TABLE>
Actually that would work if the tweeter doesn't have a crossover connected to it. You also wouldn't want to leave this connected for very long. Or you will burn your tweeters. Connect the + and - up to the tweeter watch wich way the cone moves. If it moves out then the wire connected to the + is the +. If it moves in then swap the wires.
Old Jan 3, 2004 | 09:11 AM
GSteg's Avatar
but its going to be hard to tell which way the diagphram is moving since there is the grill over it and it doesn't move much.
Old Jan 4, 2004 | 07:32 AM
toyzbus's Avatar
The tweeters will be moving 2000+ cycles per minute, it is very hard to tell if they are out of phase. I would just recommend making sure that both sides are done the same.
Old Jan 4, 2004 | 09:17 PM
o_Rage_o's Avatar
Default Re: (toyzbus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyzbus &raquo;</TD></TR><TR><TD CLASS="quote">The tweeters will be moving 2000+ cycles per minute, it is very hard to tell if they are out of phase. I would just recommend making sure that both sides are done the same. </TD></TR></TABLE>
Also with the crossover in the way the signal would not go through, hence the recommendation by nsxextreme to bypass if you do decide to try
-Shane
1991ls_crx_si
Sep 5, 2008 04:03 PM
aeboync
Southeast
Aug 15, 2008 09:33 PM
EK9Tune
Audio / Security / Video
Jan 28, 2007 02:16 PM
crohnman7
Jan 3, 2006 12:47 PM
n0 iNTegRiTY
Jul 10, 2003 07:04 PM
