Suggested frequency?
Old Jan 28, 2007 | 11:22 AM
EK9Tune's Avatar
Default Suggested frequency?
Well, I just took off the cover on my Rockford Fosgate amplifier. I was wondering, how would I decide which frequency to use? (I'd read my manual but I misplaced it somewhere)
Old Jan 28, 2007 | 11:48 AM
EBP_SI's Avatar
Default Re: Suggested frequency? (EK9Tune)
4khz.
Old Jan 28, 2007 | 11:54 AM
EK9Tune's Avatar
Care to support that? or were you just being stupid?
Old Jan 28, 2007 | 12:05 PM
EBP_SI's Avatar
Default Re: (EK9Tune)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK9Tune &raquo;</TD></TR><TR><TD CLASS="quote">Care to support that? or were you just being stupid?</TD></TR></TABLE>
from the information you provided that is the best guess i can give you. if you want to tell me whether or not you're using it for your subs, door speakers, front, rear, etc i can probably help you. without that its just picking a random number
Old Jan 28, 2007 | 12:30 PM
EK9Tune's Avatar
I mean, hey you can at least ask.
I'm using it for my subwoofers, it's a 10" Alpine Type R.
The amplifier is about 1250 watts?
Old Jan 28, 2007 | 12:42 PM
94_DC4's Avatar
Anywhere between 80hz~100hz. Just try different frequencys until you find one that you like.
Old Jan 28, 2007 | 12:47 PM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">The amplifier is about 1250 watts? </TD></TR></TABLE>
I doubt it... Model number?
4khz.
LOL!!
But seriously, to the OP, when you ask a question, it would help if you provided some specifics on your setup. It would help us give you the proper information and minimize the flames...
Old Jan 28, 2007 | 01:05 PM
EBP_SI's Avatar
Default Re: (94_DC4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94_DC4 &raquo;</TD></TR><TR><TD CLASS="quote">Anywhere between 80hz~100hz. Just try different frequencys until you find one that you like.</TD></TR></TABLE>
Id probably try somewhere between 45-70hz depending on the midbass performance of your front stage. personally i think 100hz is way to high
Old Jan 28, 2007 | 01:41 PM
EK9Tune's Avatar
Alright thanks. The amplifier is a P850.2. The head unit is a Kenwood (cant remember these things by offhand)
Old Jan 28, 2007 | 02:16 PM
fcm's Avatar
fcm
Old Fart
Your amp is 1x850W RMS into 4 ohms @ 14.4V. your sub is 500W continuous, [RMS] and it better be the SWR-1022D, [DVC 2 ohm] your amp is not stable below 4 ohms when bridged, you will wire the VCs in series for a 4 ohm final load, and you will have to be careful with the amps gain so you do not over-drive the sub, the amp is way "overpowered" for that sub.
If it is the SWR-1042D, [DVC 4 ohm] you will have to wire it in series for an 8 ohm final load, [your amp will make 425W RMS into 8 ohms] a little underpowered,
I would start at 100Hz, depending on box sub is in, and go down from there to what sounds the best to you with your music. 94
misterT
Aug 30, 2007 01:04 PM
tearinox
Apr 12, 2007 09:56 PM
JCracer723
Audio / Security / Video
Oct 1, 2005 05:55 PM
youraquickone
16
Jun 17, 2005 03:20 PM
pezzy
Sep 5, 2004 08:47 PM
