Car dies and i just dont know why...
Old Jan 2, 2004 | 05:49 PM
trooper0641's Avatar
Default Car dies and i just dont know why...
My car just dies after driving it for awhile. Whenever i drive my car for a short period of time....it just looses it's power out of no where and just dies. Showing the battery and oil sign. Whenever i try to start it...it cranks...but no start. I would then have to wait for a good 10 mins to let it cool so then it can be start up again.
Here is all the answers i got so far... altenator, battery, main relay, fuel pump, distrubutor.
Heres what i think i know....
Altenator : I dont think its my altenator because when my car dies...my lights still work. And i also did the altenator test...where i started my car...then take off the + wire from the battery...my car doesnt die.
Battery: All my lights work fine...and i dont have a sign of any dimness of the lights.
Main Relay: Im not too sure...about the main relay...
Fuel Pump / Any fuel related *****: When i start my car...it cranks...and i can also press on the gas to make the car jump...so i dont think my problem is with fuel. Plus my fuel filter is less than a month old.
Spark plugs & Wires: Replaced all new...less than 2 weeks old. NGK
Distrubutor: About 3-4 months old...but i think this is where my problem is...i think my igniter is starting to failing me. Reason why...http://www.markl.f9.co.uk/howto/elec...er/igniter.htm
It's either my main relay or my ingiter in my distrubutor.
I think its the igniter in my distrubutor...
I went to 2 shops...one man said it was distrubutor...and the other man said it was the igniter in my distrubutor.
What do you guys think? Any suggestions?
Modified by trooper0641 at 3:18 AM 1/3/2004
Old Jan 2, 2004 | 06:07 PM
1 point 6's Avatar
Down Since Day 1
Community Builder
Community Influencer
Could be losing oil preasure.
Old Jan 2, 2004 | 06:10 PM
moondoggy's Avatar
Default Re: (1 point 6)
dude, my car did exactly the same thing the other day, it died while i was driving on the highway (with the old and battery light on). i just put in a new battery, and a new distributor about a year ago. it's in the shop now, the guy thinks it's related to the timing belt. i hope it's something cheap
Old Jan 2, 2004 | 06:21 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 point 6 &raquo;</TD></TR><TR><TD CLASS="quote">Could be losing oil preasure.</TD></TR></TABLE>
I change oil every month? There are no leaks? Oil pressure? Thats a new one..
Old Jan 2, 2004 | 06:25 PM
vtecvoodoo's Avatar
Future Texas Boy
Community Builder
Default Re: Car dies and i just dont know why... (trooper0641)
check all grounds.
Old Jan 2, 2004 | 06:27 PM
Default Re: Car dies and i just dont know why... (vtecvoodoo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecvoodoo &raquo;</TD></TR><TR><TD CLASS="quote">check all grounds.</TD></TR></TABLE>
I didnt touch anything? Everything should be fine...
Old Jan 2, 2004 | 06:28 PM
Do you guys think its my igniter?
Old Jan 2, 2004 | 06:33 PM
BeerMan's Avatar
I think it is your dizzy, could be the bearing going up. What year is your civic? 92-95?
Old Jan 2, 2004 | 06:45 PM
Default Re: Car dies and i just dont know why... (BeerMan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BeerMan &raquo;</TD></TR><TR><TD CLASS="quote">I think it is your dizzy, could be the bearing going up. What year is your civic? 92-95? </TD></TR></TABLE>
Yes
Old Jan 2, 2004 | 06:51 PM
BeerMan's Avatar
I believe it was the 92 an 93 civics that had dizzy problems. I have (or, had) a 92 and the bearing went up. That was about 3 months after my igniter went up.
Goto autozone and buy a dizzy, if it doesn't solve your problem take it back.
Good luck bro.
Old Jan 2, 2004 | 06:54 PM
I have a si head...so i dont know...
Old Jan 2, 2004 | 07:28 PM
Redlined-EH3's Avatar
Well I dont know too much about cars but I know that happened to a car one time and the mechanic found the prob....it was a crank sahft sensor
Old Jan 2, 2004 | 09:18 PM
BeerMan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trooper0641 &raquo;</TD></TR><TR><TD CLASS="quote">I have a si head...so i dont know...</TD></TR></TABLE>
You mean you have a swap? Check your distributor anyway.
If not that, then check your main fuel relay.
fog raw
Jan 28, 2012 06:52 AM
jdmekrobot
Jul 3, 2009 06:20 PM
gaydm
Mar 6, 2006 08:19 PM
Unjockable
11
Aug 8, 2002 10:50 AM
