those of you with HIDs...help
ok, i just got HIDs from a 2002-TL and i have a '94 teg...i was putting on the HIDs and it worked for a couple of seconds, but my fuse was blown...and then i tried 10-watts...BLOWN....15-watts....BLOWN.....20-watts......BLOWN....30-watts....NOTHING HAPPENED...the HIDs did not even turn on....and on the bulb, it said 35W....
have u guys ever experienced this?!?!?! does anyone have any clue as to what i should do? thanx
20 fuse, thats it when i installed mine i forgot to switch them to i blew them...g..check if their reversed maybe the red is really a ground...you never know.
no, the fuse will just blow......one of mine were reversed...but mine were yellow and brown....i know a few other ht'ers had the same prob
ok, the HID on the passenger side works fine...but the one on the driver's side does not work...i tried to reverse the wires and nothing happened...i used the 30-watt fuse, but it still doesn't work even though the passenger side works....
any suggestions will be greatly appreciated...thanx!!
swap sides on the ballast and see if the problem follows... if so then it's the ballast. If not then it's something else.
ok its the ballast
....everything works....except one of the ballast.....can it be fix??
btw ,thanx for all the info guys
....everything works....except one of the ballast.....can it be fix??btw ,thanx for all the info guys
depends on what kind of problem it has.. mostlikely you'll have to find another ballast i don't think anyone actually fixes these things. the 15 amp fuse works for me.
