flooding/not firing after walbro 255 install
Old Jan 2, 2004 | 01:24 PM
primeredbeast's Avatar
Default flooding/not firing after walbro 255 install
i recently installed a walbro pump on my 89 crx dx w/b16 now car won't start.....before, it would fire right up. now it just turns over. i checked the plugs and they are filthy black and smell like raw fuel i was wanting to see if anyone has any idea of how i could fix this. also i just installed a fpr and it doesn't read and psi at alll its a stilen and i ran the fuel tank return hose to the aftermarket fpr and ran another hose from the aftermarket one to the stock one ....anyone have a clue thanks tim
Old Jan 2, 2004 | 01:41 PM
MaxSterling's Avatar
Default Re: flooding/not firing after walbro 255 install (tdgwf)
your grammer is horrible. if i understand what you are saying, you hooked up both aftermarket fpr and oem fpr together in series. that is a big no no!! only use one fpr. plus you need fuel pressure gauge to set stock fuel pressure.
Old Jan 2, 2004 | 05:15 PM
Default Re: flooding/not firing after walbro 255 install (MaxSterling)
your GRAMMER is horrible too....... j/k how would i hook up only one fpr when i have a fpr that just runs inline like an fmu??
Old Jan 2, 2004 | 05:29 PM
Muckman's Avatar
Moderator in Chief
sounds like your super rich. I bet your static fuel pressure is >100psi. take out the aftermarket fpr or get a working fuel pressure gauge.
Old Jan 2, 2004 | 05:34 PM
Default Re: flooding/not firing after walbro 255 install (Muckman)
well the problem was the same before i put the aftermarket one on.....my car ran fine before i put the damn fuel pump in thats why i dont understand why its not wanting to fire now anyone ever had a fuel pump that make your car ungodly rich?
Old Jan 2, 2004 | 06:33 PM
anyone else?
Old Jan 2, 2004 | 06:36 PM
Sonny's Avatar
Do you have a fuel pressure gauge?
Sonny
Old Jan 2, 2004 | 06:49 PM
Default Re: flooding/not firing after walbro 255 install (Sonny)
yeah its on the stillen regulator and it doesn't read anything i already checked the gauge on an air compresor and it works. i have my fpr hooked up just like anyone would hook up an fmu so i dont know what the hell is wrong anyone have anything else to help me out?
Old Jan 23, 2004 | 07:27 PM
djmatix's Avatar
Default Re: flooding/not firing after walbro 255 install (primeredbeast)
your fuel pressure is too high. Thats why its not starting. You need to buy an AEM regulator. Those B&M pieces of **** wont work. Also, I wouldnt reccomend drilling a hole in your stock regulator to lower the pressure. Your only options are to buy the AEM which will be able to lower the pressure to a workable level, or get your ecu chipped and scaled for the change in fuel pressure.
jdmhondak9
38
Jul 28, 2013 10:24 AM
oxSLEEPERxo
Dec 27, 2005 07:01 AM
hybrid_vtec
Aug 5, 2004 10:03 AM
gsrvtechatch93
Mar 12, 2004 04:33 AM
Turbolude
Aug 18, 2001 08:18 AM
