OBD1 Distributor question
Old Jan 2, 2004 | 12:27 PM
4crx4me's Avatar
Default OBD1 Distributor question
When swapping an OBD1 engine into an OBD0 car.
I know you must repin the distributor, so it will plug in and work with the OBD0 harness and wiring.
But my question is WHICH side do you repin? Do you repin the dizzy side and use the OBD0, clear white plugs, which will then match the plugs already on the engine harness.
Or, do you use the OBD1, grey ones and repin the engine side so it will match the OBD1 dizzy plugs? Simple question, I know, but is their a right or wrong way of doing it?
Old Jan 2, 2004 | 12:32 PM
James L.'s Avatar
Default Re: OBD1 Distributor question (4crx4me)
You can't use a OBD 1 Dis with a OBD 0 Ecu due to the different type trigger wheel that it use for the crank sensor. On a OBD 1 Dis, it has 24 tooth, and on a OBD 0, it has 16 tooth.
Old Jan 2, 2004 | 12:38 PM
irev210's Avatar
Default Re: OBD1 Distributor question (James L.)
yah I think he means converting the car to obd1 with a obd0 to obd1 ecu conversion harness
you can always do what I did to take advantage of your obd0 wiring harness with an obd1 wiring harness without hacking your distributor or your wiring harness
Old Jan 2, 2004 | 12:39 PM
4crx4me's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by James L. &raquo;</TD></TR><TR><TD CLASS="quote">You can't use a OBD 1 Dis with a OBD 0 Ecu due to the different type trigger wheel that it use for the crank sensor. On a OBD 1 Dis, it has 24 tooth, and on a OBD 0, it has 16 tooth.</TD></TR></TABLE>
Thanks for the help.
But maybe I wasn't clear, enough.
It's an OBD1 changeover into an OBD0 car, blown90hatch's jumper, ecu, dizzy, injectors, etc.
But I need to know WHICH dizzy plugs to repin.
The engine harness side or the dizzy side?
Old Jan 2, 2004 | 12:41 PM
4crx4me's Avatar
Default Re: OBD1 Distributor question (irev210)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by irev210 &raquo;</TD></TR><TR><TD CLASS="quote">yah I think he means converting the car to obd1 with a obd0 to obd1 ecu conversion harness
Yes irv210
But I'm not really clear on what you said, here. Can you say again?
Old Jan 2, 2004 | 12:42 PM
irev210's Avatar
do what I did...
take your old dizzy, cut the plug off
take your obd1 wiring harness, cut the dizzy plug off
All the wires match together, cept you will notice that there are 2 white wires on the obd0, the white wire that is a little fatter and has a red piece of tape at the base of the plug goes to the blue/yellow I think, or whatever wire is left over that doesnt match to anything, the other white wire goes to the obd1 white wire.
If your car doesnt start, you kow u have it backwards, but im pretty sure thats right.
Old Jan 2, 2004 | 12:47 PM
4crx4me's Avatar
Thanks great info
Now to throw a monkey wrench into those directions.
Can I do the above WITHOUT cutting anything?
Can I do it ALL by repinnig?
You know by just swapping the plugs themselves and leaving the wires intact?
Old Jan 2, 2004 | 12:51 PM
irev210's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4crx4me &raquo;</TD></TR><TR><TD CLASS="quote">
Thanks great info
You know by just swapping the plugs themselves and leaving the wires intact?</TD></TR></TABLE>
yah u can u have to unpin and repin and then then use like hot glue to keep the pins from comming out, its a hassle...
u can **** with it tho, just match the colors
Old Jan 2, 2004 | 12:54 PM
4crx4me's Avatar
So is that a "jumper" you wired up to go from the engine harness to the obd1 dizzy?
Or is that the dizzy harness itself, with an obd0 plug on it?
Pretty cool either way you did it, though.
Old Jan 2, 2004 | 12:59 PM
irev210's Avatar
its a jumper harness
you plug one side into your obd0 engine wiring harness, the other side into your obd1 distributor.
This way you have a perfectly good obd0 wiring harness if u wanna go back to stock, and a perfectly good obd1 dizzy if u ever need to sell it
Old Jan 2, 2004 | 01:05 PM
4crx4me's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by irev210 &raquo;</TD></TR><TR><TD CLASS="quote">its a jumper harness
This way you have a perfectly good obd0 wiring harness if u wanna go back to stock, and a perfectly good obd1 dizzy if u ever need to sell it</TD></TR></TABLE>
PERFECT!!
That's a BETTER idea than my original idea!
That's what I'm gonna do.
to you, thanks.
Old Jan 2, 2004 | 01:32 PM
Bizarre's Avatar
So the color of the wires are the same for OBD0 and OBD1? You just match them to make the jumper harness?
Old Jan 2, 2004 | 02:07 PM
irev210's Avatar
Default Re: OBD1 Distributor question (Bizarre)
yup, just dont forget about the 2 white wires on the obd0 side, and the 1 white wire on the obd1 side like I was saying earlier
Old Jan 6, 2004 | 07:23 AM
Bizarre's Avatar
Another quick question. Would you be able to do this the other way around? Ei. Put an OBD0 dizzy in an OBD1 car?
Old Jan 6, 2004 | 09:38 PM
4crx4me's Avatar
Default Re: (Bizarre)
No the distibutors THEMSELVES, are NOT swappable, between OBD0 and OBD1. Just the wiring. The distributor and the ecu MUST ALWAYS be the same OBD. The OBD0 dizzy is incompatable with the OBD1/2 dizzys. (there are a couple of exceptons,but as a general rule it's 90% true.)
Old Jan 7, 2004 | 04:56 AM
Bizarre's Avatar
k. Thanks for the info.
Old Jan 31, 2004 | 07:36 PM
BioXide02's Avatar
Good info
SlowB20z
Sep 3, 2012 06:30 PM
pokmijn
Aug 2, 2008 11:15 AM
89 JDM CRX
Mar 21, 2004 01:49 PM
Ruby Civic
Dec 11, 2003 04:07 AM
Norcalstoppy
Jul 13, 2002 08:02 AM
