Camshafts Break in?
Old Jan 2, 2004 | 12:22 PM
Lysawy's Avatar
Default Camshafts Break in?
Do you have to break in your new cams with only changing the cams not the rest of the valvetrain . and do you have to use non-synthetic oil to do that .
any input will help.!
oh and i searched ?????????
Old Jan 2, 2004 | 12:46 PM
irev210's Avatar
Default Re: Camshafts Break in? (Lysawy)
nope
Old Jan 2, 2004 | 01:04 PM
onePOINTsix's Avatar
Default Re: Camshafts Break in? (irev210)
you dont have to but just try not to be too rough on it for like the first 30min it's running, and synthetic is fine
Old Jan 2, 2004 | 02:24 PM
Lysawy's Avatar
Default Re: Camshafts Break in? (Sideout)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sideout &raquo;</TD></TR><TR><TD CLASS="quote">you dont have to but just try not to be too rough on it for like the first 30min it's running, and synthetic is fine</TD></TR></TABLE>
So just lube the lobes and bearings (special oil/grease that they provide)and run it for 30min on idle or constantly raise the rpm to 2000rpm or so to ensure oil to lubricate cams...!!!!!!!!!!!!!!!!!!!!
thank you for your help...
Old Jan 2, 2004 | 02:35 PM
99blackcivicSi's Avatar
Proper lube is the key then you are fine.
Old Jan 2, 2004 | 02:42 PM
irev210's Avatar
Default Re: Camshafts Break in? (99blackcivicSi)
idle for 30 min? no...
There is no break in period for cams in my opinion.
I would recommend a high quality moly lube on your rocker arms and on the cam journals.
Once your car is warmed up, and everything is fine... In my opinion, letting it idle for 30 min isnt gunna do anything. Once you turn on the car you have ~25psi of oil keeping those cam journals lubed....
Making it idle isnt gunna allow the oil to "soak in" or anything
Old Jan 2, 2004 | 10:29 PM
Lysawy's Avatar
thank you
Old Jan 3, 2004 | 04:35 AM
B18C2_sedan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lysawy &raquo;</TD></TR><TR><TD CLASS="quote">
thank you for your help...</TD></TR></TABLE>
Napa ha sthe proper lube that you need. It's called assy lube.
93itbh22hatch
34
Feb 7, 2011 02:14 PM
turbodelsolb16a2
12
Nov 30, 2010 12:17 PM
redDAinteg
Jan 6, 2008 11:57 AM
tissimo
Apr 24, 2006 03:41 PM
boosted k20
Sep 22, 2004 10:46 AM
