catalytic converter and more torque
Old Jan 2, 2004 | 11:51 AM
94accord1985's Avatar
Default catalytic converter and more torque
I have 2 questions: Will my 2.5 in/out hi flow cat directly bolt on to my 2 inch OEM piping, or should i just hollow out my cat? And how do I get more low end torque out of a f22b2?
Old Jan 2, 2004 | 12:04 PM
iam7head's Avatar
Default Re: catalytic converter and more torque (94accord1985)
it would make a difference on stock exhaust system.
dont waste your time and the oem cat, you can get a test pipe for under 20 buck.
and please dont type in bold
Old Jan 2, 2004 | 01:55 PM
fw190bvi's Avatar
Default Re: catalytic converter and more torque (iam7head)
do you know where to get a test pipe for under 20???......here in MI, once a car is 10 y/o, theres not emision/noise level restrictions
Old Jan 2, 2004 | 03:37 PM
DrunkNRacer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94accord1985 &raquo;</TD></TR><TR><TD CLASS="quote"> I have 2 questions: Will my 2.5 in/out hi flow cat directly bolt on to my 2 inch OEM piping, or should i just hollow out my cat? And how do I get more low end torque out of a f22b2?
well its obvious that the two pieces wont hookup.. you cant put 2.5" cat on a 2" exhaust.. its not kosher.. i would just hollow out your cat or take it out completely (if your state doesnt have smog laws)
Old Jan 2, 2004 | 04:12 PM
ForceThis!'s Avatar
don't do either. Unless you have some serious power upgrades, gutting your cat or trying to mount the big one on will cost you torque, not give you gains. A little backpressure is a good thing and Honda cats are already pretty damn efficient. a test pipe is not as detrimental because the diameter would stay the same, but isn't really worth it either. Do it when you go forced .
Old Jan 3, 2004 | 10:52 AM
KTeller8's Avatar
Default Re: catalytic converter and more torque (ForceThis!)
basic math
2" piping is smaller then 2.5" Inlet
so O = <FONT SIZE="6">O</FONT>
you tell me does that fit?
Old Jan 4, 2004 | 09:10 AM
ArchAngel Sabastian's Avatar
New User
Default Re: catalytic converter and more torque (KTeller8)
actually it will fit cuz the test pipes are flanges to the stock exhaust flanges thus thier all the same size less you have done exhaust work and unless your turbocharged all stock aftermarket headers for the accord use stock flanges and even more so theres the o2 sensor housing which i havent seen anyone change so.
this
http://cgi.ebay.com/ebaymotors...43632
will bolt right up to your stock exhaust and or aftermarket exhaust
but will not work if your boosted, or have changed the o2 sensor housing.
it says highflo cat in the listing but its just a hollow honeycombed Testpipe.
Old Jan 5, 2004 | 07:15 AM
Default Re: catalytic converter and more torque (ArchAngel Sabastian)
thanks
Old Jan 5, 2004 | 07:36 AM
Nick M's Avatar
If you want more low end, buy a bigger engine or bore/stroke the one you have.
Displacement = torque
4cyl's make power up high in the rev range.
Old Jan 5, 2004 | 07:40 AM
KGAccord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KTeller8 &raquo;</TD></TR><TR><TD CLASS="quote">basic math
you tell me does that fit?</TD></TR></TABLE>
haha i was thinking the same thing
socialistic
Oct 12, 2008 02:19 PM
shortlid
Jul 6, 2006 07:12 PM
spidermancivic
Dec 18, 2005 05:18 PM
Stewie
Aug 20, 2002 05:50 AM
turbogsr13z
Jul 16, 2002 06:23 AM
