ecu/chip problem
Old Jan 1, 2004 | 11:29 PM
b1698civicex's Avatar
Default ecu/chip problem
I have a 98 civic ex. I had an engine swap and now i have a (si 2000) b16a2 but when i swapped the motors my wiring harness from the b16a2 didnt work right. So now im using my old sohc ecu and wiring harness instead of my b16 ecu and wiring harness. It works fine and all but my rev limit is only at 7k rpm instead of 8200 like it is supposed to, so i really only have the d16specs. I need to know if i can buy a chip and maybe have it saudered and still use my d16 wiring harness, Im not sure what to do. thanks for your time
Old Jan 1, 2004 | 11:59 PM
PHiZ's Avatar
Default Re: ecu/chip problem (b1698civicex)
huh? What harnesses are you talking about? Engine/chassis/conversion?
Soldered, and if it's an OBD1 vtec ecu, yes it can be remapped to run the B16.
-PHiZ
Old Jan 2, 2004 | 11:19 AM
Default Re: ecu/chip problem (PHiZ)
The harness and ecu im using is the d16 sohc vtec d16, obd2.
Old Jan 2, 2004 | 11:22 AM
mmuller's Avatar
Mad Scientist
the ecu is your problem, you need a dohc vtec ecu or you need to convert to obd1 and chip one
ek coupe
81
Feb 28, 2009 07:26 PM
GODSPEED33
Jan 5, 2007 09:43 PM
b1698civicex
Jan 26, 2004 02:33 PM
Dragger817
Jun 13, 2002 12:08 PM
