Hunting Idle **Surging Idle**
Old Jan 1, 2004 | 08:14 PM
bossman032's Avatar
Default Hunting Idle **Surging Idle**
http://members.aol.com/megabighulk/huntingidle.wmv
that is the problem I am having.
I am thinking its the TPS but not sure anyone ever have this problem.
I had the same problem with my B16a Xsi 92-93 Motor and same problem with my CTR Motor I put the TPS from the XSi on the CTR Throttle BODY.....
its a CTR motor it only has one Hole inside the throttle body.
Old Jan 1, 2004 | 09:42 PM
Bee17hatch's Avatar
Default Re: Hunting Idle **Surging Idle** (bossman032)
looks like tps! but just to make sure check for any codes
Old Jan 1, 2004 | 09:45 PM
bossman032's Avatar
Default Re: Hunting Idle **Surging Idle** (Bee17hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bee17hatch &raquo;</TD></TR><TR><TD CLASS="quote">looks like tps! but just to make sure check for any codes</TD></TR></TABLE>
no codes bro
Old Jan 1, 2004 | 10:18 PM
teamols's Avatar
IS YOUR IDLE CONCERCN ON A HOT OR COLD ENGINE? SCINCE YOU DID NOT GET A TPS NOR A I.A.C. CODE MY EXPERIENCE WOUD LEAD ME TO BELEIVE THAT YOUR IAC MOOTOR IS STICKING POSSIBLY ONLY INTERMITTENLY. A VACCUM LEAK WOULD ALSO RUIN YOU IDLE QUALITY YOU MUST CLOSELY CHECK FO A VACUUM LEAK.YOUR IAC MOTOR HAS THREE 12MM NUTS YOU CAN TAKE IT OFF AND -CAREFULLY- CHECK ITS OPENING AND CLOSING(SHOULD BE RAPID) WITH A 12 VOLT SCOURCE.
Old Jan 1, 2004 | 10:22 PM
bossman032's Avatar
Default Re: Hunting Idle **Surging Idle** (teamols)
happens when the engine goes to normal temps.
Old Jan 1, 2004 | 10:59 PM
Bee17hatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teamols &raquo;</TD></TR><TR><TD CLASS="quote">IS YOUR IDLE CONCERCN ON A HOT OR COLD ENGINE? SCINCE YOU DID NOT GET A TPS NOR A I.A.C. CODE MY EXPERIENCE WOUD LEAD ME TO BELEIVE THAT YOUR IAC MOOTOR IS STICKING POSSIBLY ONLY INTERMITTENLY. A VACCUM LEAK WOULD ALSO RUIN YOU IDLE QUALITY YOU MUST CLOSELY CHECK FO A VACUUM LEAK.YOUR IAC MOTOR HAS THREE 12MM NUTS YOU CAN TAKE IT OFF AND -CAREFULLY- CHECK ITS OPENING AND CLOSING(SHOULD BE RAPID) WITH A 12 VOLT SCOURCE. </TD></TR></TABLE> check the wire harness connector for EACV and IAT sensor make sure their connect properly and in the right sensor!if thats take your EACV and you can clean it w/ some carburator cleaner.
philep_cb7_91
Feb 21, 2010 11:28 AM
got00rice
Dec 30, 2009 12:16 PM
b16a3delsol
Aug 15, 2007 09:29 AM
jdmCivic925
Oct 25, 2005 02:37 PM
wolf3007
Mar 26, 2004 05:06 AM
