taking off rear view mirrors..how to?
Old Jan 1, 2004 | 06:30 PM
ILOVEGIRLS's Avatar
Default taking off rear view mirrors..how to?
how in the world do you take off the rear view mirror for g3 integra? i tried prying the cover with a little and then big screw driver but that thing didnt even budge..someone help!
Old Jan 1, 2004 | 09:13 PM
Vtecfool's Avatar
Default Re: taking off rear view mirrors..how to? (ILOVEGIRLS)
umm why may i ask?
Old Jan 1, 2004 | 09:39 PM
esponet's Avatar
yank on it, it will come off, then you could take the 3 screws off.
Old Jan 1, 2004 | 09:43 PM
P1mpSlap's Avatar
Old Jan 2, 2004 | 12:42 AM
ILOVEGIRLS's Avatar
Default Re: (P1mpSlap)
thanks for the diagram..but i need it for the REAR view mirror.
im replacing my mirror cause it scratched up..
Old Jan 2, 2004 | 01:02 AM
Vtecfool's Avatar
Default Re: (ILOVEGIRLS)
umm, maybe try heating it up w/ a hair dryer and then try pulling it off? See if that works.
Old Jan 2, 2004 | 06:59 AM
ILOVEGIRLS's Avatar
Default Re: (Vtecfool)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vtecfool &raquo;</TD></TR><TR><TD CLASS="quote">umm, maybe try heating it up w/ a hair dryer and then try pulling it off? See if that works.</TD></TR></TABLE>
its attatched to the ceiling.
Old Jan 2, 2004 | 07:25 AM
mrmonk's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ILOVEGIRLS &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the diagram..but i need it for the REAR view mirror.
im replacing my mirror cause it scratched up..</TD></TR></TABLE>
LOL just call up the dealership the will explain how they have the diagrams in thier comps
O almost forgot ask for PARTS when they connect you
Old Jan 2, 2004 | 09:20 AM
esponet's Avatar
its on a spring tensioner, if you yank on the rear view mirror it will come off, (it won't brake), realising the tension on the base, so the screw wouldm be eisier to remove. but you also need a large phillips(+) screw driver, larger than normal.
Old Jan 2, 2004 | 11:42 AM
P1mpSlap's Avatar
Sorry I was thinking side view mirrors for some reason b/c I have to replace one of mine. lol
Here's the diagram for the rear view. It's quite simple actually.
Old Jan 2, 2004 | 01:34 PM
ILOVEGIRLS's Avatar
Default Re: taking off rear view mirrors..how to? (P1mpSlap)
thanks again..this looks so easy but prying that thing is hard!!
Old Jan 2, 2004 | 01:43 PM
mr.beeks's Avatar
LOL
it will blow it away....
the fastest way is to yanking off the hole mirror
dont worry nothing will break
execpt for the safety washer when you take apart the assembly
just straighten the washer and should be good as new.
Old Jan 2, 2004 | 08:44 PM
PushinRedline's Avatar
Default Re: (mr.beeks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr.beeks &raquo;</TD></TR><TR><TD CLASS="quote">
LOL
just straighten the washer and should be good as new.</TD></TR></TABLE>
Just yank it off man. it takes 5 seconds
Old Jan 2, 2004 | 08:48 PM
Ninja Kitty
Guest
Posts: n/a
Default Re: (PushinRedline)
it's not hard to remove the cover, there is a place to insert a flat screwdriver blade, push it all the way in and twist.
make sure you have a big phillips for the screws or you could strip them as they are on good.
Old Jan 3, 2004 | 08:20 AM
ernald711's Avatar
P1mpSlap where do you get these diagrams... they look great.
BLANCOh22a4
Feb 13, 2007 05:50 AM
int3gra07
Dec 16, 2006 10:08 PM
BryanPendleton
Jun 21, 2006 05:14 AM
typeeg
Honda Motorcycles
Nov 30, 2004 05:51 PM
DJ_SaNdOz
May 18, 2004 04:12 PM
