Are all D16 cranks the same? Mine snapped
Old Jan 1, 2004 | 04:16 PM
yellow_jacket's Avatar
Default Are all D16 cranks the same? Mine snapped
I need to know what I can replace my D16Y7 crankshaft with. It is a 96 Civic. The crank sheared off where the font pulley bolt ends. I have searched, and searched, and searched some more with no results for this motor. Thanks guys!
Old Jan 1, 2004 | 04:36 PM
PanamaVTI's Avatar
Default Re: Are all D16 cranks the same? Mine snapped (yellow_jacket)
u can use a y8 or a z6 too.
Old Jan 1, 2004 | 06:01 PM
Default Re: Are all D16 cranks the same? Mine snapped (PanamaVTI)
Thanks!
Old Jan 1, 2004 | 08:03 PM
civdx94's Avatar
d16 cranks all the same, you could even put a d17 crank in their if you can find one
Old Jan 2, 2004 | 04:51 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: Are all D16 cranks the same? Mine snapped (civdx94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civdx94 &raquo;</TD></TR><TR><TD CLASS="quote">d16 cranks all the same, you could even put a d17 crank in their if you can find one</TD></TR></TABLE>
All D16 cranks are not the same.
Is it a small snout or large snout?
This was only a issue on th 88-90 motors, after late 89, all D16's use large snout setups.
Old Jan 2, 2004 | 05:58 AM
ITRswapandslow's Avatar
get a d15 crank in there...and run customs rods....
it'd be nice to actually have a somewhat decent R/S on a d16...
all the fastest d16's run there's that way
Old Jan 2, 2004 | 06:54 AM
PanamaVTI's Avatar
Default Re: (ITRswapandslow)
yes you could run the d17 crank and rods too.. and stroke it.
Old Jan 2, 2004 | 07:41 AM
Default Re: (PanamaVTI)
I'm just looking to fix what I've got. I bought the car like this so I could just fix it and sell. Everything is perfect and it runs great. You can actually drive the thing around, you just don't have any accessories.
Anyone want to trade a head and intake manifold from a 95 Integra for one? The Integra is non v-tec. Thanks again.
Modified by yellow_jacket at 5:04 PM 1/2/2004
Old Jan 2, 2004 | 11:46 AM
Mista Bone's Avatar
D Tranny Guru
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITRswapandslow &raquo;</TD></TR><TR><TD CLASS="quote">get a d15 crank in there...and run customs rods....
all the fastest d16's run there's that way</TD></TR></TABLE>
WTF are you talking about?????
A D15 crank WILL NOT work in ANY D16 block
D16 = 55mm main journals
D15 = 45mm main journals
.400" instead of .004" main bearing clearnace = no oil pressure and alot of ratttles!
Old Jan 2, 2004 | 06:45 PM
USDM Tsuchiya's Avatar
Default Re: (Mista Bone)
d15 crank - extreamly weak
Old Jan 3, 2004 | 03:29 AM
riiiiiiiiiiiiiiiiiiiiiiiiiiight
there is a d15 crank that will work, then there is the majority of them that won't.
and no honda crank other than the h23 and f22 are weak. all of them are forged and plenty strong
Old Jan 3, 2004 | 04:40 AM
Mista Bone's Avatar
D Tranny Guru
show me the Honda D15 crank that you speak of...........if you can.
Old Jan 3, 2004 | 09:46 AM
it has yet to be shown to me...but when i was in the process of doing my last boosted SOHC...Brad (MAX_CFM) and i disscused working with the R/S a small bit...and he suggested to do what the pro's do and run a d15 crank.
Brad would have NO reason to lie to me...seeing as i do work for him...and he was wanting to build the enigne as much as i was.
i don't do SOHC stuff, but...well, he does. So i believe him. And i guess Matt Patrick being a customer would have some bearing on believing him as well.
Old Jan 3, 2004 | 10:47 AM
Mista Bone's Avatar
D Tranny Guru
the pros take a D16 crank and do a old fashion cut and weld job.
D16 crank welded and cut down to 80mm stroke/D15 main bearing size is what Bisi was using in his 1530cc SOHC monster.
He was also using LS rods before going to the alum. rods.
Matt (ZEX man) was a BIG help along with Bisi on the "old" D series board.
Old Jan 3, 2004 | 06:28 PM
Anybody know a good source for a used crank in good condition? Any of your friends have one sitting around?
Old Jan 3, 2004 | 06:34 PM
infinatenexus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PanamaVTI &raquo;</TD></TR><TR><TD CLASS="quote">yes you could run the d17 crank and rods too.. and stroke it.
I don't think the D-17 crank will for a D-16 block.
Old Jan 3, 2004 | 10:14 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">the pros take a D16 crank and do a old fashion cut and weld job.
hmm, maybe that's what Brad was saying then...just getting them DOWN TO d15 spec. Sorry for the misunderstanding. We were hella busy that day...and just bsing as usual amongst ourselves. Sorry for the mis info
But, i have a feeling that Matt will be "slightly" faster this up coming season
Old Jan 3, 2004 | 10:40 PM
Mista Bone's Avatar
D Tranny Guru
Matt had better be faster!!!!!!!
I know he is running alot more weight than Bisi, but Bisi was running all motor and Matt was turbo + spray.
300 whp vs. 450 whp
Sometimes trying to get too much power down just makes you slower.
BTW I hit the link to Brads page, where the hell did that big *** degree wheel come from??? Finally someone using the correct tools.
Old Jan 4, 2004 | 04:44 AM
yay, someone finally noticed teh "Wheel" That would be Howard Shoaf.
yeah, Brad picked that up at a recent auction from a Nascar team. Got a good deal...and it will be put to GOOD use.
and 450? i hope to see a little more than that outta Matt's setup
Old Jan 5, 2004 | 09:52 AM
PanamaVTI's Avatar
Default Re: (infinatenexus)
yes it does work.
Old Jan 27, 2004 | 07:37 PM
As per your recommendations, I purchased a z6 crank. Unfortunately the mains are no where near to the same size.
BraveHeartSOHC
Jan 11, 2014 11:38 PM
Bense
Sep 5, 2007 02:10 PM
the jdmchop
Oct 21, 2005 07:28 AM
jjaskula1
Mar 19, 2005 01:07 PM
soundman
Nov 4, 2003 06:51 PM
