ls into eg ?
im putting a obd1 ls motor in my 95dx hatch i dont need to add any sensors in right but i think i do need to swap the connectors on a few any help would be appreciated
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asmallsol »</TD></TR><TR><TD CLASS="quote">It depends what ECU you use. I am pretty sure that the LS does have a Knock sensor. If there is any wiring, it will be one to two wires tops. </TD></TR></TABLE>
LS motors don't have a knock sensor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jcstites »</TD></TR><TR><TD CLASS="quote">everything plugs right up... only thing i had to do was extend the o2 sensor wires, they wouldnt reach. i used my civic wiring harness.</TD></TR></TABLE>
Or if you're using and obd2 harness the O2 plug is found under the IM and plugs straight down into the header.
