Here is a ? that might stump you.......
Old Dec 31, 2003 | 08:49 PM
GTlvr82's Avatar
Default Here is a ? that might stump you.......
Can bad piston rings cause a pressure surge?? The motor that I am getting has a erratic idle that goes from 1500 to 2000 and the builder of the motor says that it could be the piston rings that aren't seated right. Can that happen????????? Is that possible? If this makes no sense lemme know...I will be sober in the morneing...........Happy New Years.
EDIT: It is a B20/GSR.....with intake headers and exhaust...
Old Dec 31, 2003 | 09:01 PM
spnfed's Avatar
Default Re: Here is a ? that might stump you....... (GTlvr82)
How much did you pay or are you paying for this dud motor?
Old Dec 31, 2003 | 09:03 PM
GTlvr82's Avatar
Default Re: Here is a ? that might stump you....... (spnfed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spnfed &raquo;</TD></TR><TR><TD CLASS="quote">How much did you pay or are you paying for this dud motor?</TD></TR></TABLE>
Not relavent...the question IS the thread...thanks...and it is not a dud...it still runs 13's.....with slips to prove it... i I have seen them.
Old Jan 1, 2004 | 01:04 AM
Jimmy's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GTlvr82 &raquo;</TD></TR><TR><TD CLASS="quote">Can bad piston rings cause a pressure surge?? The motor that I am getting has a erratic idle that goes from 1500 to 2000 and the builder of the motor says that it could be the piston rings that aren't seated right. Can that happen????????? Is that possible? If this makes no sense lemme know...I will be sober in the morneing...........Happy New Years.
EDIT: It is a B20/GSR.....with intake <FONT SIZE="3">headers</FONT> and exhaust...</TD></TR></TABLE>
I could of swore that headers were on fords,chevys???
This thread is not relavent...try the tech section and search...
Old Jan 1, 2004 | 10:55 AM
mysi92's Avatar
map sensor
Old Jan 1, 2004 | 11:06 AM
Good ol' Screwtape's Avatar
Multi-paradigm
Default Re: Here is a ? that might stump you....... (mysi92)
Are you throwing any codes?
It could be your IACV.
Does it idle like that all the time? Just when it's cold? Just when it's warm?
Schwat?
Old Jan 1, 2004 | 11:13 AM
NonovUrbizniz's Avatar
Loved
check your coolant level too... that is a VERY common cause of surging idle in honda's...
Check the radiator level... and the resivior... but it's usually when it's down in the radiator.
I don't think rings would cause anything like that... I can ask a guy I work with tomorrow... he may know.
Old Jan 1, 2004 | 01:37 PM
spnfed's Avatar
Wo, didn't mean to offend you.
How many miles does it have, and how was the engine broken in?
94vtecsi
Feb 6, 2008 06:46 PM
JFG Kevin
May 30, 2006 12:07 PM
bmw626
Jun 7, 2005 08:31 AM
explictness
10
Aug 29, 2004 02:57 PM
hondaguyef
Jul 8, 2004 02:51 AM
