Here is a ? that might stump you.......
Can bad piston rings cause a pressure surge?? The motor that I am getting has a erratic idle that goes from 1500 to 2000 and the builder of the motor says that it could be the piston rings that aren't seated right. Can that happen????????? Is that possible? If this makes no sense lemme know...I will be sober in the morneing...........Happy New Years.
EDIT: It is a B20/GSR.....with intake headers and exhaust...
Re: Here is a ? that might stump you....... (spnfed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spnfed »</TD></TR><TR><TD CLASS="quote">How much did you pay or are you paying for this dud motor?</TD></TR></TABLE>
Not relavent...the question IS the thread...thanks...and it is not a dud...it still runs 13's.....with slips to prove it... i I have seen them.
Global Moderator
Re: Here is a ? that might stump you....... (GTlvr82)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GTlvr82 »</TD></TR><TR><TD CLASS="quote">Can bad piston rings cause a pressure surge?? The motor that I am getting has a erratic idle that goes from 1500 to 2000 and the builder of the motor says that it could be the piston rings that aren't seated right. Can that happen????????? Is that possible? If this makes no sense lemme know...I will be sober in the morneing...........Happy New Years.
EDIT: It is a B20/GSR.....with intake <FONT SIZE="3">headers</FONT> and exhaust...</TD></TR></TABLE>
I could of swore that headers were on fords,chevys???
This thread is not relavent...try the tech section and search...
Multi-paradigm
Re: Here is a ? that might stump you....... (mysi92)
Are you throwing any codes?
It could be your IACV.
Does it idle like that all the time? Just when it's cold? Just when it's warm?
Schwat?
Schwat?
check your coolant level too... that is a VERY common cause of surging idle in honda's...
Check the radiator level... and the resivior... but it's usually when it's down in the radiator.
I don't think rings would cause anything like that... I can ask a guy I work with tomorrow... he may know.
