HELP ASAP!!!! Dealer Says Non Honda Transmission Fluid Will Void Warrenty!!!!
Old Sep 25, 2001 | 02:45 PM
onyx00's Avatar
Default HELP ASAP!!!! Dealer Says Non Honda Transmission Fluid Will Void Warrenty!!!!
Acura dealer just told em that using non Honda brand transmission fluid would void my warrenty. I brought it to them to have the tranny looked at and to put GM Synchromesh in and now they tell me I can't use the GM Synchromesh, it is goign to void my warrenty if I do (he said if something with my tranny goes wrong later on then they will blame it on the non Honda fluid).
Anyone!? Is this true!!!?!?!?! Help!!!!!!
Old Sep 25, 2001 | 02:54 PM
Cosworth's Avatar
Default Re: HELP ASAP!!!! Dealer Says Non Honda Transmission Fluid Will Void Warrenty!!!! (onyx00)
Use Honda MTF . Any reason for using GM stuff?
Old Sep 25, 2001 | 02:55 PM
Big Phat R's Avatar
Honda's motto is "Don't open your hood to strangers". A lot of dealers will insist on Honda only stuff - for good reason - but voiding your warranty is a little over the top. I would suggest going to a less constipated dealer in the future.
Why do you need to use the GM stuff?? Don't tell me it's cheaper.
Old Sep 25, 2001 | 03:50 PM
red97gsr's Avatar
Default Re: HELP ASAP!!!! Dealer Says Non Honda Transmission Fluid Will Void Warrenty!!!! (Big Phat R)
Don't know about the warranty thing, but I did hear that GM synchromesh was pretty good stuff though.
Nighthawk GS-R's Avatar
New User
its defiently true. it happned to my friend
Old Sep 25, 2001 | 06:55 PM
nsxtcjr's Avatar
New User
Default Re: HELP ASAP!!!! Dealer Says Non Honda Transmission Fluid Will Void Warrenty!!!! (Nighthawk GS-R)
It won't void your warranty as long as what you use matches the spec required for the R. Do they specify motor oil or transmission fluid for the R? Some Honda transmissions need motor oil. Anyway, Honda transmission fluid probably IS the best thing for your car, so why not just use it?
Old Sep 25, 2001 | 10:23 PM
jimbob's Avatar
New User
Default Re: HELP ASAP!!!! Dealer Says Non Honda Transmission Fluid Will Void Warrenty!!!! (nsxtcjr)
It shouldn't void the warranty provided it matches the spec like nsxtcjr said. There are standards for transmission fluid and a law specifies that no manufacturer can void warranty if a compatible part is used in place of the original. Not totally sure, but Honda may use certain friction modifyers in their fluid. Redline(MTL or MT-90) and BG Synchroshift has such friction modifyers. Some others do as well and if it meets the spec Honda uses, there's no legal reason they can void your warranty.
If you don't put the right thing in though, they are entitled to void your warranty.
But just because you use Mobile 1 instead of the Honda stuff doesn't mean you also void the engine warranty!
Old Sep 25, 2001 | 10:30 PM
Rboosted717's Avatar
Default Re: HELP ASAP!!!! Dealer Says Non Honda Transmission Fluid Will Void Warrenty!!!! (jimbob)
However I've heard several people say that using different brake fluid will void certain warrenty issues with the brakes. I will find out soon when I go to the dealership to get a new brake master installed on the car with Super blue fluid, Comptech/Goodridge SS lines, Porterfield R4S pads, StopTech rotors, and Spoon calipers! hhaahahahaha I wonder what they will say! However I will say this, the brake master has been screwed up way before any of this, however I doubt that they will believe me!
Old Sep 25, 2001 | 10:31 PM
Type Goch's Avatar
New User
Default Re: HELP ASAP!!!! Dealer Says Non Honda Transmission Fluid Will Void Warrenty!!!! (Rboosted717)
if they say no..see if they know your friend benjamin...
[Modified by Type Goch, 11:31 PM 9/25/2001]
Old Sep 25, 2001 | 10:47 PM
jimbob's Avatar
New User
Again, it's just a matter of compatibility. If you put in DOT 5 in your system, they'll never warranty it. Most if not all Honda braking systems uses DOT 3 compatible fluid. DOT3, DOT4 and DOT5.1 are all compatible fluids so if you use either one, it's fine.
ATE super blue is DOT4 stuff, but if Honda really wanted, they could get you on a technicality. It's not DOT approved. Just because it's blue... ATE makes the same fluid in clear that IS DOT approved.
Old Sep 26, 2001 | 08:39 AM
fastbrakes's Avatar
Default Most brake parts are not warranted
Most if not all manufacturers consider the brake system components to be wear items, and not covered by the warranty...sometimes you'll get a sympathetic dealer who will replace the MC, but not very often.
Old Sep 26, 2001 | 09:23 AM
Jesse H's Avatar
Default Re: Most brake parts are not warranted (fastbrakes)
if they do void the warranty, it should only apply to the tranny warranty.
eurocrx
Jul 24, 2010 12:37 PM
krazycivic4u
Jun 3, 2006 08:18 PM
honda011
Jun 5, 2005 06:51 PM
972drcordex
Jan 10, 2005 04:58 PM
JDM EJ1 95
Jun 3, 2004 08:54 PM
