Strange Ticking Noise??
Old Dec 31, 2003 | 07:06 PM
89civichatchback's Avatar
Default Strange Ticking Noise??
Ok i just now got my DOHC ZC in my car, and it has been runnin well! But now i hear this tickin noise in the engine bay whenever im on the gas, it only does it above 3,000RPM or so. And if im not down on the gas, it will only do it at 3,000RPM and at 55MPH, not anywhere above that! IM not undestanding what it could be? I havent really dawged the engine out much!! I surely hope it isnt a spun rod bearing? What are the symptoms of that?
Old Dec 31, 2003 | 07:21 PM
bump
Old Dec 31, 2003 | 07:49 PM
Akiraboy's Avatar
How many miles?
maybe a valve? adj
Do you live in a cold weather climate?
Old Dec 31, 2003 | 08:39 PM
ThatRicerDaniel's Avatar
Default Re: (akiraboy)
if not valves then dizzy.
Old Dec 31, 2003 | 10:39 PM
Akiraboy's Avatar
Default Re: (NitrousDreamz)
https://honda-tech.com/zerothread?id=713598
Old Jan 2, 2004 | 09:53 AM
I live in TN, its not that cold here right now, and i dunno the timing could be off? What should I do? Should i advance it all the way? How do i adjust the valves? What about the dizzy? I know there is nothing wrong with that.
Old Jan 3, 2004 | 08:23 AM
ttt
Old Jan 3, 2004 | 08:56 AM
StupidSlowRSX's Avatar
check exhaust/header bolts.... mine did the same thing... i had a nut fall off the header so there was just a bolt dangleing and it would viberate then i revved it
Stevo F
Jul 14, 2014 07:25 PM
MODsjtown
Jan 4, 2005 01:05 PM
89civichatchback
Dec 31, 2003 08:02 PM
coolgsr
Dec 16, 2003 07:30 AM
Comptech98GSR
Aug 28, 2002 12:34 PM
