S-T sway/tie combo with 2.5" exhaust
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheGSRGuy »</TD></TR><TR><TD CLASS="quote">Sway bars don't present clearance issues, but lower tie bars do.</TD></TR></TABLE>
Sway Bars cause clearence problems not lower tie bars
B18c1995 I barely clear with my SRR set up & 2.5" .. my clearance will change one I get rid of my Apex N1 an slap on my Es muffler
When I had it installed I took off the abs Bracket you can see it runs through the center of the two bolts for the mounting of the tie bar there is sort of a dip under there the abs line is crushed or anything from when I looked at it but the only down fall is that the bar is 19mm
Would the S/T sway bar/tie bar, which is 19mm work well in conjuction with my nuespeed sport springs and kyb agx shocks for the occasional auto-x? or would it be too large/small?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96 Ls lnTeG »</TD></TR><TR><TD CLASS="quote">
Holy chit... Where did you find that tie bar from?
</TD></TR></TABLE>Holy chit... Where did you find that tie bar from?
XtremeCarTuner
I got it from andrew @ Perpetualconcepts he is a forum sponsor I think I paid about the 200 dollar area for tie an sway bar...
b18c1995
I am not to sure if it would be enough for the ocasional auto x for me it all fun for me I am out just to build my car for myself peace
b18c1995
Blue-Civic-Hybrid
Jan 21, 2003 05:13 PM
