Overheating and the Heater quit not work
Old Dec 31, 2003 | 12:10 PM
Greg123's Avatar
Default Overheating and the Heater quit not work
I was idleing one day in the cold weather. Heater "was" working fine then all the sudden it kinda fadded away and got cold. I was like wtf and drove it home. Before I even got home the temp gauge was getting really hot near the red so I pulled over let it cool down and then drove the rest of the way home. and the heat still did not work during the overheating, just cold air. Sounds like a water pump to me since the heat did not work. Can anyone please help me with this?? Thanks It's an 89 CRX HF 5-speed
Old Dec 31, 2003 | 12:11 PM
crxgator's Avatar
Default Re: Overheating and the Heater quit not work (Greg123)
try a new thermostat first...
Old Dec 31, 2003 | 12:12 PM
EF4lyfe's Avatar
Im sorry to tell you this, but this is your headgasket and you know what that means head gasket = $$$ unless you can do it yourself
Old Dec 31, 2003 | 12:15 PM
Ya@inlinePRO's Avatar
Default Re: Overheating and the Heater quit not work (SIhatch90)
check to see for leaks in the radiator. just replaced one on my accord with the same symptoms.
Old Dec 31, 2003 | 12:16 PM
Greg123's Avatar
Default Re: Overheating and the Heater quit not work (kwik2nec)
I replaced the Thermostat a couple weeks ago so it's new. Even if the head gasket was blown the heat should still work because the water is still flowing threw the head/heater core correct??
Old Dec 31, 2003 | 12:17 PM
Greg123's Avatar
Also there are no leaks
Old Dec 31, 2003 | 12:23 PM
EF4lyfe's Avatar
when your heat goes, and your car is overheating, this means your head gasket hard to believe but im sorry
Old Dec 31, 2003 | 12:38 PM
onePOINTsix's Avatar
Default Re: (SIhatch90)
if it overheats when you get on the gas then it's a headgasket, and they only cost $23 at your local autozone
Old Dec 31, 2003 | 12:43 PM
ZC88CRX's Avatar
Default Re: (Sideout)
ha.... i have the exact same prob.... replaced thermostate a month ago. heat works for 2 weeks
then a week ago, nothing. no heat
so i changed the thermostate again today and wabam!! overheating plus no heat.
i hate my ****** car
UnknownDC2
Mar 19, 2008 07:33 PM
discman
Jan 18, 2008 07:56 AM
superstock2
Aug 15, 2006 06:04 PM
dbman96
Oct 27, 2001 08:05 AM
