Stuck ignition Rotor!!
I bought the stuff to do a minor tune- up, got to my ignition rotor and it is stuck like a bitch. CAn someone pleaze help me this is my only car so i need it fixed. How can I get it off? Thanks Car 1992 civic LX w/ 95 d15b7
did you take the retaining screw off? If not you need to click the engine over until the screw faces the little gap in the dizzy. If you did take it off I'm not sure what is causing it...
mine was stuck on there pretty good, despite removing the screw holding it in place. same motor exactly, d15b7, not that it should make any difference. but yeah, if you have already taken that screw out, just keep at it, pry it off, it'll give.
