cap/rotor replacement - help!!!
Old Dec 30, 2002 | 07:00 PM
magic hat #9's Avatar
Default cap/rotor replacement - help!!!
i've removed the cap, but i cannot get the rotor off. i've looked at the replacement rotor and i can see where the retaining screw is located, but i can't rotate the old rotor to remove the screw. can i turn over the motor (it won't start without the cap & wires plugged in) to spin the rotor and hope it stops with the screw exposed? i can't imagine this is the proper method.
Old Dec 30, 2002 | 07:04 PM
Bimmer99's Avatar
Default Re: cap/rotor replacement - help!!! (magic hat #9)
you need to bump the motor till you can see the screw which should be facing the firewall
Batoutahell's Avatar
Hitting the starter for short bursts is an acceptable method of aligning the screw, but it can take a few hits to get it right. I prefer to turn the crank by hand; there's a cut-out in the splash shield to insert a socket/ratchet.
Old Dec 30, 2002 | 07:09 PM
CPR's Avatar
CPR
Default Re: cap/rotor replacement - help!!! (Batoutahell)
Just as if you were doing a valve adjustment...
Old Dec 30, 2002 | 07:12 PM
migs's Avatar
Default Re: cap/rotor replacement - help!!! (Bimmer99)
andrew714
Dec 9, 2007 09:57 PM
street_ride14
Mar 21, 2006 05:02 AM
Doom325
Mar 16, 2006 10:48 PM
93SSPHatch
May 31, 2002 04:13 AM
93SSPHatch
May 30, 2002 02:55 PM
