greddy turbo timer installation for 88-91 civic
i post it in the force induction forum and didnt get much respond..since this is only for 88-91 civic..i would like to ask here..for those of you that is using a greddy turbo timer and has an alarm..i would like to know how do you guys hook it up? i did a search, but all i get is that same picture of the ignition wiring..but i read a site that says its only effective for 5th and 6th gen civic and 3rd gen integ. so nothing for 4th gen. heres the site.. http://importnut.net/turbotimer.htm
i just installed one a few days ago
all u need to do is find the IGN, the ON, and the BATT cables from the ign switch...........
also the ebrake cable and the speed sensor
not too hard to hookup.. just follow the directions for the 3 cables on the lil red manual
i didnt get a manual with my timer cuz i got it used. theres only 4 wires coming out of the timer tho. i also have an alarm..so how will i hook it up with my alarm working?
I could stand to know which wires go where, also... The way mine's wired up now, the radio stays on, but the engine cuts off.
haha..at least you got urs to work. now..i know someone here has to know how to wire it the right way! someone please help us!
are you trying to get them to work together? If you are, you are going to have to add a relay to the wiring of the turbo timer so that you can arm the car while it is still running...side note your shock sensor is going to set off the alarm due to the car runnning. If you are looking for a relay diagram post in the audio section and one of those guys will prob help you out..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiR Kid »</TD></TR><TR><TD CLASS="quote">I could stand to know which wires go where, also... The way mine's wired up now, the radio stays on, but the engine cuts off. <IMG NAME="icon" SRC="https://honda-tech.com/forums/images/smilies/mad.gif" BORDER="0"> </TD></TR></TABLE>
i don't know much about installing turbo timer's... i'm actually searching now trying to find out exactly which tires to tap but from what i've read it sounds to me like you have your IGN and ACC wires (blue and green) reversed.
Can anyone verify this for SiR Kid?
-Erik
-Erik
crashtest Sonny
Dec 26, 2003 07:52 PM
