You Can Thank Me Later (MPFI related)...
Old Dec 30, 2003 | 07:36 PM
FourthGenHatch's Avatar
Default You Can Thank Me Later (MPFI related)...
http://www.fourthgenhatch.com/mpfi.html
I just spent several hours scanning my helms manual wire by wire to find out every difference between the DPFI and MPFI connections to the ECU. I have them listed by wire color each for DPFI and MPFI side by side and than what each one of those wires goes to/function it serves.
There is a chart on that page with it, you can't miss it. I hope this helps the MPFI hopeless.
Old Dec 30, 2003 | 07:55 PM
Red_Si's Avatar
Default Re: You Can Thank Me Later (MPFI related)... (FourthGenHatch)
awwww, did you make this for me and home skillet??? how sweet!!! lol
anyways, i hope it helps and we can get my car running tomorrow.
Old Dec 30, 2003 | 07:59 PM
2point2's Avatar
NICE writeup!... wish it was around when i did this the first time.
Old Dec 30, 2003 | 08:01 PM
Hcivic88's Avatar
Default Re: You Can Thank Me Later (2point2)
that is a really good write up
to you....
Old Dec 30, 2003 | 08:05 PM
phatrick2332's Avatar
that will help people x1000
your the bestest
Old Dec 30, 2003 | 08:28 PM
Home Skillet's Avatar
Ahh sweet nuggets of mercy!!! Thanks mang! Hey, how about them Hooter wings?
Old Dec 30, 2003 | 08:30 PM
crxgator's Avatar
Default Re: You Can Thank Me Later (Home Skillet)
good write-up...hopefully no more MPFI questions, just search for your website...
Old Dec 30, 2003 | 11:54 PM
4crx4me's Avatar
Kudos to you, my friend Well Done and Bravo!
Old Dec 31, 2003 | 02:56 AM
One other thing it is good for is if you have a MPFI DX your wires are in the right spot but the colors might be all wrong. So this will help track some problem wires people have down.
And as I told my girlfriend I did this for the good of mankind because I don't think I ever saw something which seems such a simple layout of the entire ECU pins. If this saves one EF from going to the scrap heap than my work is done.
Old Dec 31, 2003 | 03:18 AM
USDM 4G VTEC's Avatar
Default Re: You Can Thank Me Later (FourthGenHatch)
great write up
for such a good job
i am planning on getting drunk tonite and celebrate for you
Old Dec 31, 2003 | 10:02 AM
MonkeyMagic's Avatar
excellent write-up, get this into the FAQ thread ASAP!
Old Dec 31, 2003 | 11:08 AM
Silt's Avatar
Default Re: You Can Thank Me Later (lilredej2)
*bows down*
holy **** man. i love you! this is great.
Old Dec 31, 2003 | 12:06 PM
EGturbocoupe's Avatar
what head bolts did you use, i'm building a mini-me from a Y7 block and Z6 head and the Z6 head bolts won't screw in the Y7 block hit me up at blindbirde@aol.com thanks
Old Dec 31, 2003 | 02:08 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGturbocoupe &raquo;</TD></TR><TR><TD CLASS="quote">what head bolts did you use, i'm building a mini-me from a Y7 block and Z6 head and the Z6 head bolts won't screw in the Y7 block hit me up at blindbirde@aol.com thanks</TD></TR></TABLE>
Headbolts? I have a DOHC ZC, straight drop in, no need to take anything apart.
Old Dec 31, 2003 | 02:32 PM
wpgcivic's Avatar
ive already seen this site, it was given to me on here when i was doing my mpfi and it worked great
Old Dec 31, 2003 | 03:34 PM
Default Re:
The MPFI instructions have been there for many months, its this new chart I made that I just put up.
Old Dec 31, 2003 | 03:38 PM
matt j's Avatar
Default Re: Re: (FourthGenHatch)
great stuff FourthGenHatch, this definately needs to be in the FYI section!
Old Dec 31, 2003 | 06:44 PM
Ben Ogle's Avatar
Default Re: Re: (matt j)
Hey, I'm gonna put a link in my swap guide on my site, cool? that way i dont have to write one up. Heh.
ben
Old Dec 31, 2003 | 09:33 PM
tilt's Avatar
I'm going to do the swap tomorrow. The chart is definitely helpful. thanks.
Old Dec 31, 2003 | 10:05 PM
civickiller's Avatar
Default Re: You Can Thank Me Later (tilt)
what i did was use connectors at the ecu so it would make it easy to go back to dpfi is needed. which i found really handy since my ls motor had serious rod knock and was no good and now im going back to dpfi so im really glad i used the connectors so its really easy now. and i also did that plug thing so i could easy disconnect the added dist and injector wires
Old Jan 1, 2004 | 09:24 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civickiller &raquo;</TD></TR><TR><TD CLASS="quote">what i did was use connectors at the ecu so it would make it easy to go back to dpfi is needed. which i found really handy since my ls motor had serious rod knock and was no good and now im going back to dpfi so im really glad i used the connectors so its really easy now. and i also did that plug thing so i could easy disconnect the added dist and injector wires</TD></TR></TABLE>
I always use OEM plugs anytime I do any wiring. I like to keep my stuff looking stock.
I'm putting in some foglights soon so I'm going to the junkyard for all kinds of OEM plugs and relays to use for it.
Modified by FourthGenHatch at 9:20 PM 1/1/2004
Old Jan 1, 2004 | 10:14 AM
4crx4me's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FourthGenHatch &raquo;</TD></TR><TR><TD CLASS="quote">
I'm putting in some foglights soon so I'm going to the yunkyard for all kinds of OEM plugs and relays to use for it.</TD></TR></TABLE>
I agree with fourthgenhatch.
I ONLY use OEM stock, as well. It makes it harder to find everything you need and you really have to THINK more about it. Like trying to locate the right connectors and all. LOL It takes time, but it's worth it in the end as no-one can tell the difference between what was stock wiring and what I added. And the guys at the junkyards I go to, don't even care about wires and connectors, they give them away. So, it costs me nothing to use the stock wiring. Now, if I could only find a place or source for honda ecu and connector pins, I'd be set. Anyone have any. LOL
Old Jan 1, 2004 | 10:55 AM
W0oT's Avatar
Banned
don't forget the dizzy plug. for the d16 you'll need too.
btw maybe you could figure out whats wrong w/ my mpfi, i used your site. boggs when i hit throttle, switched tps and dizzy wires...... check the link
https://honda-tech.com/zerothread?id=710334
Old Jan 1, 2004 | 12:22 PM
Default Re: You Can Thank Me Later (Nismo240sx1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nismo240sx1 &raquo;</TD></TR><TR><TD CLASS="quote">don't forget the dizzy plug. for the d16 you'll need too.
[/url] </TD></TR></TABLE>
Did you solder all the connections? My car ran like *** because my injector plugs were sort of crimped onto the old ones. Than I got new plugs and solder right onto the wires from those and it has ran great.
Bogging in general could be old distributor cap, plugs, and wires. Replace those if you haven't already.
Old Jan 1, 2004 | 04:27 PM
W0oT's Avatar
Banned
yup everything was soldered and most were shrinkwrapped or electrical taped at the least.... changed plugs, cap/rotor, pcv, thermostat, timing belt, water pump, front main seal ect..... all honda oem
