88 crx hf w\b16a: temp gauge is acting funny
Old Dec 30, 2003 | 05:44 PM
Project_ED8's Avatar
Default 88 crx hf w\b16a: temp gauge is acting funny
when i'm at idle my temp gauge is at the normal position but when i start to drive the car hard or take it up high in the rpm's the gauge goes cold and usually stays that way until i just let my car idle then it returns to its normal position. why is this? i was doing a search some say its the water pump and or could it be a bad thermostat or bad coolant temp switch? or maybe its a loose ground or dirty connection? well just let me know what ya guys think. ok thanks
Old Dec 30, 2003 | 08:37 PM
crxgator's Avatar
Default Re: 88 crx hf w\b16a: temp gauge is acting funny (Project_ED8)
for me, it was a loose wire by the sensor which is under the distributor...download the online helms and check it out...should tell you how to check it with a multimeter...
Old Dec 30, 2003 | 08:44 PM
bossman032's Avatar
my car does the same exact thing I guess.
I have no termostat.
Old Dec 31, 2003 | 02:56 AM
undefinedcrx's Avatar
yeah he's right i had the same problem. its the wire located under the distributor. mine was covered in oil from a leaking seal on the distrib. so either its dirty or it just came out. the wire is a female clip, single, and plugs into a nipple on the head.
haha that sounded kinda off.
civais
Aug 14, 2015 03:11 AM
ZCHondaCRX91
May 15, 2012 06:33 AM
supracrx
12
Dec 2, 2005 08:11 AM
eth0r
Nov 10, 2005 03:31 AM
VTECR021
Apr 22, 2004 08:04 PM
