what are the diff between 98-01 p72?
Yes, I was refering to the ECU...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC »</TD></TR><TR><TD CLASS="quote">Addition of the immobilizer function.</TD></TR></TABLE>
If I buy someone elses ECU does this mean my car theoretically wont start with their ECU?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra-modder »</TD></TR><TR><TD CLASS="quote">If I buy someone elses ECU does this mean my car theoretically wont start with their ECU?</TD></TR></TABLE>
can anyone verify this?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by youngvedder »</TD></TR><TR><TD CLASS="quote">i have an '01 GSr and put in a OBD I P08 ECU and had no problems....I switch back and forth sometimes, and no probs....
YV</TD></TR></TABLE>
the harness matches up?
Are you asking about OBD 2a and OBD 2b differences? And how to identify which is which?
Click the link:
http://hondata.com/techecuid.html
Modified by i2un at 8:32 PM 1/6/2004
Click the link:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackSage »</TD></TR><TR><TD CLASS="quote">I believe there is a OBDII-OBDI harness. So it can be done.</TD></TR></TABLE>
Correct. But it is technically OBD2a - OBD1 harness. And OBD2b - OBD1 harness.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra-modder »</TD></TR><TR><TD CLASS="quote">What is the ECU in an 01 GSR? is it a P72 ODB IIa?</TD></TR></TABLE>
It should be a P72 OBD IIb. But you should check the connectors to make sure. If you click the link I posted above....you can see the differences in ECU's from the picture. Oldest on the bottom- Newest on top.
I have a 98 Gsr and that used a P72 OBD2a Ecu. In certain late model 98 GSR's on up they used P72 OBD2b Ecu's.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by i2un »</TD></TR><TR><TD CLASS="quote">Your 01 Ecu should use the left 3 plugs and have a open space at the end. My OBD2a Ecu has a space in the center. </TD></TR></TABLE>
Correct, however my ecu doesnt have that rubber thing on the left side as the hondata page shows.
Correct, however my ecu doesnt have that rubber thing on the left side as the hondata page shows.</TD></TR></TABLE>
The rubber thing on the side isn't anything. Your just looking for the pins for the connector plugs of the harness.
