temperature gauge not working after overheating...
Old Dec 29, 2003 | 07:14 PM
SPORT INJECTION's Avatar
Default temperature gauge not working after overheating...
Lost coolant the other day and forgot to top off.
SO..... my car overheated tonight. I let it cool and topped it off. It seems to be running just fine now but the temp gauge doesnt move from cool. It doesnt even go up to normal temp. Is there a possibilty I killed a sensor?
Thanks for any help for the dummie.....
Old Dec 29, 2003 | 07:41 PM
crxgator's Avatar
Default Re: temperature gauge not working after overheating... (SPORT INJECTION)
did you bleed the system? if there is air trapped in there, it will mess the gauge reading up...
Old Dec 30, 2003 | 05:18 AM
Home Skillet's Avatar
Check your radiator cap, that is one of the most overlooked items. That solved my overheating.
Old Dec 30, 2003 | 06:31 AM
speed_racer012's Avatar
Default Re: temperature gauge not working after overheating... (Home Skillet)
or your coolant temp sensor and your thermostat. had that problem twice, once was the sensor the other was the thermostat.
it's two cheap and easy to fix things too.
Old Dec 31, 2003 | 07:00 AM
Default Re: temperature gauge not working after overheating... (speed_racer012)
thermostat is only a few months old....
where is the sensor located?
..and is it called the thermosensor?
Old Dec 31, 2003 | 04:13 PM
maybe the thermostat is broke and stuck open now?
Old Oct 31, 2004 | 05:33 PM
asiansgoweeee's Avatar
Hey how did you end up fixing the problem because recently a heater hose busted and coolant leaked out and almost overheated. after replacing the radiator hose and topping the radiator off the temp gauge stopped working. thanks
Old Oct 31, 2004 | 10:36 PM
drussell4801's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPORT INJECTION &raquo;</TD></TR><TR><TD CLASS="quote">maybe the thermostat is broke and stuck open now?</TD></TR></TABLE>
I would replace it before you bother doing any other tests.
they're dirt cheap.
replace it and bleed the system and if you still don't get a temp reading then start looking into checking the sensor wires for continuity.
It's highly unlikely that overheating destroyed the sensor. They're made to work at high temps so that you know when it's overheating..
ARL97
Jun 3, 2017 10:07 AM
wseg
Nov 7, 2015 08:27 AM
obuhmyuh
Mar 7, 2010 01:27 PM
stocker2shocker91
Mar 24, 2008 01:19 PM
PearlWhiteAccord
Dec 20, 2004 06:43 PM
