Turn Signals wont work
Ok ive tried jsut about everything i could think of but they just wont work. Its not a fuse or blown bulb. If i hit the hazards they come on but when i use the **** on the wheel they wont work. Any one ever had this issue and solved it? Someone said that i might a a ground issue but i dont no where they are grounded. HELP need to fix for inspection lol
well if neither of them work, then either check for a ground in the circuit, or maybe a relay, since you check the fuse and its fine, then start tracing the wires from your signals and work on back till you can find a problem, and use a test light or volt meter.
well its not the relay for sure cause the hazards wouldnt even work. ive tried tracing the wires but they lead to a giant bundle inside a loom so thats impossible. ith ink it might be my assymbly cause the windsheild wiper relay wont work either
homade intake and muffler thats it as far as mods period
Well one day i was driving after installing my clear turn signals and i forgot the screw so it fell out and got run over and the socket got ripped off to
luckly i had 3 so i replaced the socket and turn signal. it worked fine for like a week and now just wont wurk at all
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ferio 95 »</TD></TR><TR><TD CLASS="quote">Well one day i was driving after installing my clear turn signals and i forgot the screw so it fell out and got run over and the socket got ripped off to
luckly i had 3 so i replaced the socket and turn signal. it worked fine for like a week and now just wont wurk at all</TD></TR></TABLE>
Make sure the wires are still intact (and making a connection)
I would start there, but if that is fine, then the Combo switch may be suspect.
luckly i had 3 so i replaced the socket and turn signal. it worked fine for like a week and now just wont wurk at all</TD></TR></TABLE>Make sure the wires are still intact (and making a connection)
I'm not real familiar with these but -
most every car that I've been around - the 4-ways are on a kinda' separate circuit - 4 ways will work but turns won't or vice-versa.
I'd be skeptical that a new combo switch is going to solve the problem and I'm guessing that a combo switch isn't cheap.
It's just bad ju-ju to try to solve electrical problems by slamming-in new parts.
Wait for more replies - find a wiring diagram/service manual, etc- diagnose the problem first or pay someone to do it, maybe
But, then again, I could be wrong....again
