turning signal problem.
Old Dec 29, 2003 | 09:23 AM
reeder321's Avatar
Default turning signal problem.
The other day I installed clear corners on my 93 civic and now the right signal blinks twice as fast as the right signal. what happened and how do I fix this?
thanx
Old Dec 29, 2003 | 09:27 AM
DaX's Avatar
DaX
Loved
Community Favorite
fast flashing blinker means one of your bulbs is blown. Check front and rear bulbs.
Old Dec 29, 2003 | 09:37 AM
reeder321's Avatar
Default Re: (DaX)
None of the blinkers are blown. Thats why I'm confused
Old Dec 29, 2003 | 05:52 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: (reeder321)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by reeder321 &raquo;</TD></TR><TR><TD CLASS="quote">None of the blinkers are blown. Thats why I'm confused </TD></TR></TABLE>
Remember the corner lights use 1157 bulbs....in which has two lighting filaments...just because one is still "unbroken" that doesnt' mean it is working properly. Check your bulbs again..
Old Dec 29, 2003 | 07:40 PM
Unit 01's Avatar
If you used the bulbs that came with your clear corners (usually orange), definitely replace it with your stock bulbs. I once bought a set of clear corners that came with 1-filament orange bulbs. I was wondering why-tf my turn signals was all fux0rzed up...until I checked the bulbs
Old Dec 29, 2003 | 08:02 PM
Soccerking3000's Avatar
Default Re: (Unit 01)
same thing here got black corners and put the bilbs it came with and they worked half of the time when turning on the parking lights but when i went to turn the signals on nothing happened and then all of a sudden they blinked real fast just used the stock ones and everything turned out okay
EL Vap133
Apr 16, 2008 09:06 AM
lmike6453
Mar 5, 2008 05:02 PM
PotatoePAPA
16
Jan 12, 2005 12:15 PM
kylem
Jul 24, 2004 03:45 PM
B16ED4G
Feb 27, 2002 07:43 AM
