JDM GSR pistons????????
Old Dec 27, 2003 | 01:11 PM
Hybrid CRX's Avatar
New User
Default JDM GSR pistons????????
I heard these are the same as USDM Type R pistons. Anyone know?
Also where and what kind of rings would i get for this piston?
Old Dec 27, 2003 | 01:23 PM
Casey's Avatar
Default Re: JDM GSR pistons???????? (Hybrid CRX)
not the exact same, and any oem rings for whatever bore it is (standard/overbore) should work
Old Dec 27, 2003 | 07:06 PM
Hybrid CRX's Avatar
New User
Default Re: JDM GSR pistons???????? (Casey)
thanks
anyone else
Old Dec 27, 2003 | 07:26 PM
JDMb18civic's Avatar
i dont think its physically the same...but it does have the same comp ratio
gsr head gives more comp than the b16/itr head
Old Dec 31, 2003 | 10:16 AM
Hybrid CRX's Avatar
New User
anyone know the comp rarion of JDM gsr's then?
Old Dec 31, 2003 | 10:20 AM
IN VTEC's Avatar
Default Re: (Hybrid CRX)
They spec it at 10.6:1...same as USDM ITR, but they get there two different ways.
Old Dec 31, 2003 | 10:53 AM
99-DC2's Avatar
the piston dome cc's are different... the USDM ITR's are a bit higher than JDM GSR's due to the fact that ITR heads have larger combustion dome volume than GSR heads... also another difference is that ITR's are coated and GSR's are not, makes it more "slippery" and resistant to heat, more friendly for higher revving...
Old Dec 31, 2003 | 11:45 AM
eyeamvic's Avatar
In a GSR the USDM ITR pistons will give you 10.8:1 and the JDM GSR will give you 10.6:1
Old Dec 31, 2003 | 07:28 PM
sgT's Avatar
sgT
Default Re: (DC2-99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2-99 &raquo;</TD></TR><TR><TD CLASS="quote">also another difference is that ITR's are coated and GSR's are not, makes it more "slippery" and resistant to heat, more friendly for higher revving...</TD></TR></TABLE>
Slippery because the moly coating retains oil. Doesnt do anything for heat resistance though.
I3ackfire
May 15, 2004 09:47 AM
94TealGSR
Nov 30, 2002 01:05 AM
phantoman
Nov 21, 2002 12:09 PM
B19CivicHB
Sep 11, 2002 01:34 PM
vtec8k
Feb 15, 2002 11:32 AM
