How does my clutch/flywheel look?
Old Dec 25, 2003 | 07:47 PM
Wo-Nelly's Avatar
Default How does my clutch/flywheel look?
Is it reuseable? It's an act extream with a street disc.
stock flywheel
Old Dec 25, 2003 | 09:33 PM
JDM_Risa's Avatar
Default Re: How does my clutch/flywheel look? (GottaLude)
ya flywheel looks bad .........i dunno if resurfacing it will help for the clutch and pp replace it since its out anyways.............that **** is warped.....pretty bad.
Old Dec 25, 2003 | 09:41 PM
nevin's Avatar
and I thought mine was bad
Old Dec 25, 2003 | 10:05 PM
ACTman's Avatar
I have seen a lot worse.
The flywheel shows cracks, which is a scary proposition. It is a time bomb and should be replaced. BTW, we now have XACT flywheels available which will get you the best quality (oops, I guess I am partial) and save some cha-ching over any competitors flywheels.
The pressure plate shows some pretty good hot spots but as long as it is fairly flat and there are no cracks, you should be fine. It also looks fairly old, before we were using ductile iron and certifying them to SFI specs, but it is hard to tell for sure fromt the photos. Any cracks in a gray iron casting would be a big concern.
I don't know what the disc measures but they start off at .315" thick. They can last all the way to about .240" thick.
Old Dec 25, 2003 | 10:07 PM
Bulldogg83's Avatar
dude everything looks fine! you should be good for another 100,000 miles!
Old Dec 25, 2003 | 10:14 PM
Full-Race Javier's Avatar
Default Re: How does my clutch/flywheel look? (Bulldogg83)
flywheel looks pretty bad...but ive seen worse plates and disks
jons silvia trans blew up one day, i guess it didnt like the 60-1....take a look
OEM disk
what was left
more
a resurfaced flywheel (in good condition) helps a lot
Old Dec 25, 2003 | 10:34 PM
FredoSP's Avatar
alittle OT but when you install the flywheel bolts do you guys use/suggest red or blue locktite?
thanks!
Old Dec 26, 2003 | 01:10 AM
aw1234dude's Avatar
Default Re: How does my clutch/flywheel look? (FredoSP)
Ha ha same problem on my friends boosted impreza 2.5rs.
https://honda-tech.com/zerothread?id=615111
Old Dec 26, 2003 | 03:04 AM
the-anti-crack's Avatar
fi it were my ride, i wouldnt use any of it.
1 im a big fan of light weight flywheels.
2 the pressure plate and flywheel are pretty bad.
3 ther is life left on the disc, but nto a lot.
thats IMO
Old Dec 26, 2003 | 08:27 AM
rocket256's Avatar
How in the world did it get like that?
Old Dec 26, 2003 | 08:44 AM
GRTechnologies's Avatar
Default Re: How does my clutch/flywheel look? (ACTman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ACTman &raquo;</TD></TR><TR><TD CLASS="quote">I have seen a lot worse.
I don't know what the disc measures but they start off at .315" thick. They can last all the way to about .240" thick.</TD></TR></TABLE>
i used an ACT clutch in my car with a H22 and it broke the pp plate straps at the track . not to say there bad. but there flywheels are nicely priced and work well.
Old Dec 26, 2003 | 08:45 AM
Flamenco-T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FredoSP &raquo;</TD></TR><TR><TD CLASS="quote">alittle OT but when you install the flywheel bolts do you guys use/suggest red or blue locktite?
thanks!</TD></TR></TABLE>
I used red every single time
stan
Giant_Bean
Jan 27, 2012 06:32 PM
the.hamburglar
Aug 14, 2005 10:39 PM
Cypher0117
Jun 12, 2005 03:50 PM
Rocks
Aug 23, 2004 12:27 PM
LSTEG96
Mar 18, 2004 11:53 PM
