headgasket r&r
Old Dec 25, 2003 | 12:51 PM
wanabecivicex's Avatar
Default headgasket r&r
so im replacing my head gasket and i set the head down. then i hear something snap. yeah, its the hose on the bottom side of the intake manifold from the pcv valve. is there anyway i can continue to headgasket replacement, or do i need to wait and order that molded hose from acura?
Old Dec 25, 2003 | 01:11 PM
Zerob16eg's Avatar
you can continue with the headgasket replacement. if it is just the hose you can get a generic hose from schucks or napa. the only problem you will have is if you replace the head/intake mani, it is a major hassle to reach around the head and hook up the hose up again.
Old Dec 25, 2003 | 01:15 PM
Default Re: (Zerob16eg)
removing the intake manifold is something i want to try to avoid.
Old Dec 25, 2003 | 04:46 PM
Foozball26's Avatar
Default Re: (wanabecivicex)
well the "hose" you are talking about made the snap sound b/c it is plastic.
The only problem with just using a hose is that the pcv valve is in the middle of that plastic hose. a replacment can be hand for cheap (bitch to get out of the intake manifold) or just disable the system.
justadream
Feb 12, 2011 10:02 AM
.one lane
Nov 13, 2005 11:41 AM
zx2gotboost
Sep 25, 2005 07:03 PM
houstondigital
Aug 29, 2005 11:48 AM
Nikoli
Oct 26, 2004 02:40 PM
