d16a1, dohc zc question
Old Dec 25, 2003 | 12:46 AM
Arthur's Avatar
Default d16a1, dohc zc question
i know the d16a1 makes less power but what is the cause of that? lower compression? different cams, more free flowing head? the Whole head?
Old Dec 25, 2003 | 07:43 AM
4genaccordfreak's Avatar
has no vtec.. and its just a les powerful engine.. my buddy and i built up his car with zc and we turbo'd it.. he ran 14.7 at only 6 psi which isn't great but not bad.. but for alil more $$$ were now going b16a with t3/04e turbo waaaay better swap
Old Dec 25, 2003 | 03:22 PM
Arthur's Avatar
Default Re: (4genaccordfreak)
thd dohc ZC is Also non vtec......i was asking what are the differences between the two that cause the differences in power. sheesh
Old Dec 25, 2003 | 06:57 PM
blackeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4genaccordfreak &raquo;</TD></TR><TR><TD CLASS="quote">has no vtec.. and its just a les powerful engine.. my buddy and i built up his car with zc and we turbo'd it.. he ran 14.7 at only 6 psi which isn't great but not bad.. but for alil more $$$ were now going b16a with t3/04e turbo waaaay better swap</TD></TR></TABLE>
the guy that does my work has a turbo zc in an 86 si. he ran like 12.4 on 12psi i think
Old Dec 25, 2003 | 07:20 PM
The_Head's Avatar
Default Re: d16a1, dohc zc question (Arthur)
It's NonVTEC which has been mentioned before. It does have lower compression than a B16A as well. The redline is lower too.
Old Dec 25, 2003 | 09:48 PM
4crx4me's Avatar
Try the http://www.thezcresource.com or http://www.quickhonda.net for info on zc differences
Old Dec 26, 2003 | 10:20 PM
Arthur's Avatar
Default Re: d16a1, dohc zc question (4crx4me)
i made mo reference to the B series engines, or a sohc ZC, or a vtec d series. i asked about the DOHC zc and the D16A1. what causes the horsepower differences in the near identical engines.
If your unable to answer the question Dont reply, and dont tell me there isnt any ******* Vtec. BECAUSE NEITHER THE D16A1 or THE DOHC ZC HAVE IT. GOD
Old Dec 27, 2003 | 09:32 AM
jlicrx's Avatar
higher compression pistons - different camshafts - better intake manifold - better throttle body (A1 has dual butterflies) - 4-2-1 exhaust manifold
Old Dec 27, 2003 | 11:23 AM
Arthur's Avatar
Default Re: d16a1, dohc zc question (jlicrx)
So if i could get ahold of a dohc ZC head, complete with intake/TB would i be able to just fit it to the d16a1?
Old Dec 27, 2003 | 01:44 PM
The_Head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arthur &raquo;</TD></TR><TR><TD CLASS="quote">If your unable to answer the question Dont reply, and dont tell me there isnt any ******* Vtec. BECAUSE NEITHER THE D16A1 or THE DOHC ZC HAVE IT. GOD</TD></TR></TABLE>
Calm down man. I misunderstood you. Theres no need to throw an E-fit about it.
The D16A1 is an DOHC ZC. I guess the DOHC ZC you are referring to is the D16A8/9. One main difference between the two motors is that the A1 had vaccum advance and an external coil, while the A8 had timing controlled by the computer and an internal coil distributor. I think the A8 had a higher redline too which means more HP, but am not 100% sure about it.
I have a 3rd gen civic, the ZC motors from the 86-89 Tegs are an easy swap for it, so I've been looking into them a little bit.
Old Dec 27, 2003 | 06:12 PM
onePOINTsix's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">higher compression pistons - different camshafts - better intake manifold - better throttle body (A1 has dual butterflies) - 4-2-1 exhaust manifold</TD></TR></TABLE>no it deffinataly dosent, i have a A1 intake mani and TB sitting next to me and it has 1 TB butterfly, BTW this is from a 89 Teg, might be differnet on older A1s
Old Dec 27, 2003 | 06:14 PM
Default Re: d16a1, dohc zc question (EW1_The_Head_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EW1_The_Head_ &raquo;</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE>yes but only on pre-88 models oh and a higher redline dosn't nessicarily mean it makaes more power, it just means it can rev higher
89_ZC_crx
Feb 25, 2006 07:20 PM
integracivic94
19
Nov 5, 2003 12:00 PM
russian_racer
16
Jul 29, 2003 11:45 PM
89civichatchback
May 3, 2003 04:34 PM
Rydaddy
Oct 30, 2002 12:53 PM
