cold shift prob[tranny gurus]
Old Dec 24, 2003 | 01:21 PM
machine4321's Avatar
Default cold shift prob[tranny gurus]
95 jdm h22 in an accord with 340 000 kilometers on it ...
in the morning i shift into revers with no problem but once i stop and take it out of reverse it will not go into any gear what so ever ...i pump the clutch i get the car to roll i bring thre pedal up slowly and try to find the "spot" and nothing ...finally i get mad cuase im already late for work i slam it into gear and it goes in ....even driving when a little cold at intersections it doesnt want to go into 1st untill i slam it in ..
When i slam it in it grinds a bit and almost drives away with the clutch all the way in ....it definitly doesnt feel like its disengauging
could this be a sign of a weak clutch cylinder/slave cylinder ...again when it warms up it seems to work ok with the odd problem here and there ???
Old Dec 25, 2003 | 06:43 PM
up
Old Dec 27, 2003 | 08:50 PM
up up
Old Dec 29, 2003 | 04:31 PM
sigh ..i didnt think it would be this hard
Old Dec 29, 2003 | 09:45 PM
piotrush's Avatar
Default Re: (machine4321)
well, im not tranny guru but its could also be your synchros, if not then most likely your clutch since it does it in every gear and not just specific ones. hope that helps
Old Dec 30, 2003 | 08:39 AM
Timmy Joe's Avatar
Default Re: cold shift prob[tranny gurus] (machine4321)
This sounds like it needs a clutch adjustment or low on clutch fluid or needs to be bled out. clutch shop can usually blled the system and replace new fluid for around $35.00
Old Dec 30, 2003 | 08:44 AM
Sephro's Avatar
Default Re: cold shift prob[tranny gurus] (Timmy Joe)
How old is your clutch?
Have you checked the fluid level on the clutch master cyl?? Might want to change the fluid.
You say in only does this when it is cold? Or does it do this all the time.
I am thinking it is more of a clutch problem than a tranny problem.
Old Dec 30, 2003 | 05:48 PM
clutch was done late summer ....fluid was new about a month after(due to bleeding the system) its been bled so much ..as in i took a month to get ir right ...and ya pretty much when its cold.....also i wonder about my shift cables..theve got 340 000 kilometers on them
thanks
Old Dec 31, 2003 | 05:50 AM
Sephro's Avatar
Okay when did you change the tranny fluid?? If you running regular motor oil (as the manual tells you to...) you may want to try sychromesh...
I highly doubt it's the cables.. I have 210,000 miles on mine and no problems plus it wouldn't get better as it the car warmed up.
Old Jan 2, 2004 | 09:29 PM
clutch/tranny fluid.clutch fluid were all new in aug of 03...
i really need to check the slave cylinder and all that ..i had a friends delsol out one night and it was locling after revers...turns out his slave cylinder was bad...
Old Jan 2, 2004 | 09:37 PM
kb798's Avatar
Don't slam it into gear. That only makes things worse. From your description of the problem, I'm guessing it's the synchros.
Have you tried double-clutching to get into gear?
Old Jan 3, 2004 | 06:36 PM
i can pump the clutch as many times as i want...doesnt help......
ive found after i back up it lets me go into 3rd...all i have to do is move the car an inch or so in 3rd and it will let me go into gear no problem
Old Jan 6, 2004 | 12:14 PM
up ....joel you should know this one ....
didnt you have a problem getting stuck in gear...?
Old Jan 6, 2004 | 12:20 PM
piotrush's Avatar
Mine sometimes gets stuck in reverse when I start it in the morning, only once in a blue m,oon though. Once I back up a foot it gets out of reverse and into all gears fine. I wonder if its a related problem.
Old Jan 6, 2004 | 12:43 PM
biglew's Avatar
Can you put in into gear with the engine turned off?
Old Jan 6, 2004 | 04:07 PM
hummm not to sure ..ill have to check in the mornig
Old Jan 6, 2004 | 09:24 PM
Matgallis's Avatar
i believe joel bent a shift fork. he missed shifted and hit inbetween 2 and 4th (correct me if i am wrong)
EDIT: does ur clutch pedal give any resistance? Defaintly check the fluid, thats a no brainer...
Old Jan 6, 2004 | 09:29 PM
Matgallis's Avatar
Default Re: (92`Legend)
I just remembered when I Had my clutch problem it was doing something similar to urs. Do u drop the clutch a lot? is ur clutch stock? I am betting on the clutch being bad. Check your fluids and if u can't find the problem take it to a clutch specialtist and try to get a lower price on the inspection.
If it doesn't go into gears easy, don't force it. If it's not ur syncros u do not want to damage them by forcing the gears..
Old Jan 7, 2004 | 09:35 AM
ludefreek's Avatar
i ran across a problem like this once in a 2g teg. turns out the input shaft bearing was bad.
Old Jan 7, 2004 | 09:48 AM
Sephro's Avatar
Default Re: (ludefreek)
the only thing that is puzling me and making me think it has to be soemthing differnt than you guys are saying is because he said it is fine once it warms up... Problems don't usually go away like that.
Old Jan 7, 2004 | 06:27 PM
good call on the imput shafl bearing ...my tranny makes *** loads of noise when the clutch is engaged...but goes quiet when its depressed
thanks for the replies
hopp[efully i can get a garage tomorrow and start to figure this out ..theres 3 feet of snow on the ground
integranator
Jun 22, 2008 04:04 PM
fred92htch
Aug 23, 2004 01:54 PM
95GSRTT
Aug 16, 2004 04:34 PM
Pikachu
Apr 20, 2004 11:29 AM
mchuang
Mar 9, 2004 05:14 AM
