Can I fix it?
Old Dec 24, 2003 | 08:55 AM
blackgrrl23's Avatar
Default Can I fix it?
I have a 1991 civic LX with the stock D15B2. I suspect my headgasket is leaking and is about to blow since I am overheating badly. I also need a new water pump. Other than that, the car runs fine. Basically, what I need to know is if it is worth my time fixing the problems, or should I just get a "used" engine and start over. The rest of the car is in excellent shape. If you suggest a used one, how much do you think the installation would be? Where may I find one online? I am a single mom (see avatar) and $$ is tight. Thanks everyone for your help and suggestions.
EDIT: I know the waterpump is the cause of the overheating since I just replaced the radiator/t-stat last week and the car is leaking badly from the drivers side near the timing belt area.
EDIT 2: Does anyone in NOVA want to help me fix the car/swap the engine? I can pay cash....PM me to discuss....
Old Dec 24, 2003 | 10:23 AM
Jimmy's Avatar
Global Moderator
Default Re: Can I fix it? (blackgrrl23)
Yeah i'd definetly go ahead and get a timing belt also..
Good luck bro
Old Dec 24, 2003 | 11:06 AM
mattssi's Avatar
Default Re: Can I fix it? (USDMDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDMDC2 &raquo;</TD></TR><TR><TD CLASS="quote">
Good luck bro </TD></TR></TABLE>
Make that sis..... lol
Old Dec 24, 2003 | 11:10 AM
Kendall's Avatar
Well, there are shops that have d series motors lying around, they'd probably give you one in great shape for no more than a hundred bucks or so. I'd definatly look into replacing it.
Old Dec 26, 2003 | 03:48 AM
Default Re: (dc231)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc231 &raquo;</TD></TR><TR><TD CLASS="quote">Well, there are shops that have d series motors lying around, they'd probably give you one in great shape for no more than a hundred bucks or so. I'd definatly look into replacing it.</TD></TR></TABLE>
That is "plan B". First, I am trying to change the pump/belt. i found someone to do that for me for $50
if that doesn't work, it's swap time!
Old Dec 26, 2003 | 03:49 AM
Default Re: Can I fix it? (mattssi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattssi &raquo;</TD></TR><TR><TD CLASS="quote">
Make that sis..... lol</TD></TR></TABLE>
Watch out for the blackgrrl!
Old Dec 26, 2003 | 07:22 AM
mattssi's Avatar
If you can get it done by someone that knows what they are doing for 50 bucks, then i say do it!
Old Dec 26, 2003 | 07:26 AM
ZaksZCrex's Avatar
Default Re: (mattssi)
go for it 50$ dang most shops wont change a timing belt for that but watch out people now a days unless you know the person good luck
Old Dec 26, 2003 | 08:54 AM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
good luck..i wish i was closer or i would do it for free......big for a single MOM...keep us posted.
DarkBB4
Mar 18, 2005 11:26 AM
scuba123
Aug 4, 2004 05:50 AM
Rhythm Racer
14
Mar 1, 2004 08:16 PM
