got a ALPINE HEADUNIT AND im gettin NO SOUND
Old Dec 24, 2003 | 08:27 AM
s2000june's Avatar
Default got a ALPINE HEADUNIT AND im gettin NO SOUND
I got this alpine headunit
its hooked up RIGHT cause im gettin sound and everything
only when im listening to the radio but when i put in a CD im not hearing anything
when i first hooked it up i kept gettin some INNTERUPT that kept flashing
if any 1 knows how i can fix this problem so i can listen to cds
please help me
thanx
Old Dec 24, 2003 | 11:08 AM
HiRevn's Avatar
Default Re: got a ALPINE HEADUNIT AND im gettin NO SOUND (civicrida3)
I'm not sure what HU you have, but on my 9813, when you remove the faceplate, there is a little hole on it where you could insert a pin to reset it. I would try that. If you call Alpine (1-800-alpine1 I think) that's the first thing they will tell you to try. If that doesn't work, I would ask the guys at the place you bought it from or simply just exchange it.
Old Dec 24, 2003 | 11:29 AM
s2000june's Avatar
aight thanks
imma mess wit it some more.
if that dont work imma call aLpine and see what the prob is
ill prolly have to tell the model and stuff 2.
aight thanks
Old Dec 24, 2003 | 11:12 PM
clm's Avatar
clm
Default Re: (civicrida3)
Is it a burned or scratched CD? That could be your problem.
Old Dec 25, 2003 | 09:46 AM
Wesyder's Avatar
do you have any amps if so the alpine has two remote wires one for amp one for power antenna the one for power antenna loses power when you put a cd in because obviously when listening to cd you dont need the antenna
Old Dec 31, 2003 | 12:12 PM
s2000june's Avatar
im trying to say that i can listen to the radio
but when i put in a real cd
its lights up showing the track and its playing
but im getting no sound like its muted
i dunno why
is there sumthing i have connected wrong
Old Dec 31, 2003 | 12:19 PM
MAV3RiCK478's Avatar
its broken, somewhere from the laser sending the signal to the speaker wires. if its new return it if you bought it used your kind of SOL.
Old Jan 2, 2004 | 09:17 AM
foz's Avatar
foz
Default Re: got a ALPINE HEADUNIT AND im gettin NO SOUND (Wesyder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wesyder &raquo;</TD></TR><TR><TD CLASS="quote"> alpine has two remote wires one for amp one for power antenna the one for power antenna loses power when you put a cd in because obviously when listening to cd you dont need the antenna </TD></TR></TABLE>
this is the most common mistake... look behind the radio at the connections
the blue/white is the remote amp turn-on
the blue is the power antennea
sounds like you connected blue where you should have connected blue/white
if your not sure than disconnect the blue wire you have connected and see if you lose sound from the radio, if that's case just try the blue/white and throw a cd in. If that's not it then that unit needs to be serviced, but is still an uncommon error with alpine radios
Old Jan 3, 2004 | 08:34 PM
faiz_23's Avatar
Default Re: got a ALPINE HEADUNIT AND im gettin NO SOUND (foz)
i had the exact same problem. in my alpine 7892. i think you might have the same. alping has an interrupt feature. so if you hookup you cellphone or something, and a phone call comes in, it will mute it all. i am not exactly sure which wire. but look for an interrupt or mute wire on the harness, my wire was stripped and touching the chassy so it was grouinding out. that should help
Old Jan 4, 2004 | 12:00 AM
brizjuan's Avatar
my advice to you would be to go to ur local car audio store and purchase a wiring harness for about 15 bux... it will eliminate all ur wire splicing problems... you just simply click together both connectors and your ready to go....
Old Jan 4, 2004 | 07:26 AM
toyzbus's Avatar
Your pink/black wire is touching ground and is muting the deck. Make sure that you terminate the end of that wire and you will be fine.
Old Jan 5, 2004 | 05:15 AM
foz's Avatar
foz
Default Re: (toyzbus)
The pink wire is the mute wire, however that's not the problem, since it has sound when listening to the radio, but not when listening to cd's
he needs to check his remote turn-on wire
Old Jan 5, 2004 | 06:14 AM
toyzbus's Avatar
I just read the part of his post about the Interrupt showing up on the display. He does just need to hook up the blue/white to turn on the amp instead of the blue. The pink must be intermitently shorting to ground to cause the interrupt earlier on, so it should be terminated nonetheless.
Old Jan 6, 2004 | 07:12 PM
s2000june's Avatar
thanks for all yalls help
i figured it out with yalls help
on the back of the head unit
theres 2 blue wires
mines not labeled or doenst have white stripes
just 2 blue wires
im not sure wich 1 i had hooked up but it wasnt workin i just spliced the other blue 1 too togetther and i ran it to the wire from the remote spot on my amp.
RADIO AND CD PLAYER WORKS AND IM HAPPY
thanks guys
hONDA TECHERS !! are the greatest!!
LyFeOfAnAzN
Audio / Security / Video
May 3, 2009 08:25 PM
Jdmglenn
Oct 24, 2006 11:18 AM
teg969
Apr 20, 2005 01:43 PM
only1crx
May 19, 2004 06:56 PM
JTCdudeman
Apr 1, 2003 11:20 AM
