Is the problem my IACV?
Old Dec 24, 2003 | 08:10 AM
quik2kSi's Avatar
Default Is the problem my IACV?
Ok, whenever i come to a stop or simply push in the clutch to let the car idle the rpm's fall to idle then raise to about 1300-1500 rpm's for about 10 sec. then just fall back to idle. i have checked time and time again for a vac leak and do not have one. i have, however, messed with the idle adjustment screw to raise the idle since i put in some ES motor inserts so the idle isn't so rough. i have cleaned out my IACV once before and it seemed better for about a day or two and then it goes crazy again. i have thrown a CEL, cleaned the IACV, then reset the ECU, and once again... fuct up idle . can someone please help me out? Thanks
Old Dec 24, 2003 | 10:24 AM
Jimmy's Avatar
Global Moderator
Default Re: Is the problem my IACV? (quik2kSi)
Sounds like a vaccum...try borrowing a friends IACV.
Old Dec 26, 2003 | 03:24 AM
Xsi's Avatar
Xsi
Have you moved you throttle position sensor or changed TB's recently? if so then check the settings on the TPS.
Old Dec 26, 2003 | 12:06 PM
Newt Dog's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quik2kSi &raquo;</TD></TR><TR><TD CLASS="quote">Ok, whenever i come to a stop or simply push in the clutch to let the car idle the rpm's fall to idle then raise to about 1300-1500 rpm's for about 10 sec. then just fall back to idle. i have checked time and time again for a vac leak and do not have one. i have, however, messed with the idle adjustment screw to raise the idle since i put in some ES motor inserts so the idle isn't so rough. i have cleaned out my IACV once before and it seemed better for about a day or two and then it goes crazy again. i have thrown a CEL, cleaned the IACV, then reset the ECU, and once again... fuct up idle . can someone please help me out? Thanks</TD></TR></TABLE>
If the idle is going up and down, Check coolant, Ignition timing, TPS and make sure your throttle body is not gumed up.
Also check your coolant temp sensor.. Sometime's the wires break off.
Old Dec 27, 2003 | 08:31 AM
Mista Bone's Avatar
D Tranny Guru
FITV (Fast idle thermo valve) coming loose, happens with ES motor mount inserts.
Old Dec 27, 2003 | 09:04 AM
fkncivic's Avatar
what sucks is with the iac for honda alot of them are different sizes and bolt patterns
LukieLuc
Sep 19, 2007 07:37 PM
go2sleep
Jun 15, 2006 08:54 PM
mikeunreal2
11
Mar 23, 2006 12:00 PM
UNKNOWN_MEMBER
Apr 20, 2005 12:39 AM
Civic Racer X 7
Jul 23, 2003 07:19 AM
