Custom exhaust problem,what to do?
Old Dec 23, 2003 | 08:56 PM
hondacivic4g's Avatar
Default Custom exhaust problem,what to do?
I'm going to have a custom exhaust run. It's going to be set up similar to the RS*R GT 2 Spec exhaust. I've got a Magnaflow high flow cat,resinator and muffler, all 2.25" inlet/oulet(except muffler 2.25" inlet 2.5" race core/4"tip). The car is being set up for road racing. I've got a semi-street/mild race N/A set up, using a D15/16 hybrid. What i'm trying to figure out or find the best solution for, is the header to exhaust. The header is a Neuspeed N2 4-2-1 (2pc). The collectors outlet is only 1.75", the exhaust i'm going to run is going to be 2.25". Now should I just have a custom piece made to couple the header to the cat, essentially stepping it? Or would it be best to cut the collector pipe off and replace the 1.75" tubing w/ 2.25"? Any suggestion or solutions are welcome.
Thanks-Jason
Old Dec 24, 2003 | 06:42 AM
fulldragcrx's Avatar
either way would be fine. If you were really worried about power youd prob run open header any way right?
Old Dec 24, 2003 | 11:36 AM
Kendall's Avatar
Default Re: (fulldragcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fulldragcrx &raquo;</TD></TR><TR><TD CLASS="quote">either way would be fine. If you were really worried about power youd prob run open header any way right?</TD></TR></TABLE>
Of course if he ran with an open header, he'd need earplugs and aspirin.
Old Dec 26, 2003 | 07:08 PM
Default Re: Custom exhaust problem,what to do? (hondacivic4g)
TTT
switched_in_your_eye
Honda Civic (2006 - 2015)
17
May 2, 2009 05:44 PM
msinsky14
Jul 15, 2006 10:21 AM
prkiller
12
Jan 31, 2004 10:54 AM
rizen
Sep 17, 2003 05:29 AM
DMF
Sep 13, 2002 03:51 PM
