Cams for turbo setup on B20/P73. ECU suggestions. Your opinions please
Old Dec 23, 2003 | 07:34 PM
jonyb's Avatar
Default Cams for turbo setup on B20/P73. ECU suggestions. Your opinions please
Going turbo. My current setup is JDM ITR motor. Head has the following mods:
Skunk2 Stage2's with cam gears
Ferrea valves
Skunk2 IM
AEM fuel parts
Stock block
Going to this:
t3/t4 turbo (Revhard kit I think)
B20 block sleeved by Golden Eagle 84.5mm
Arais 9:0 pistons
Eagle rods
440 RC's
ITR water pump, oil pump, etc...
What cams should I use with this setup. I'm going to sell the Skunk2's. Just looking for the best setup with the low compression. Also, I've got the stock JDM ITR ECU that I'm thinking about going with Hondata S200. Any suggestions? Thanks in advance..
Modified by jonyb at 10:48 PM 12/23/2003
Old Dec 24, 2003 | 05:34 AM
jonyb's Avatar
Default Re: Cams for turbo setup on B20/P73. ECU suggestions. Your opinions please (jonyb)
ttt
Old Dec 24, 2003 | 01:44 PM
NVturbo's Avatar
O.G. triple O.G.
Go with CROWER...i still have my "403" from my N/A setup in there....soon to be replaced by turbo setup trim cams...
ECU....hmm...make sure your cylinder head and bottom end can handle the higher revs....or say "bye-bye" to your motor
Old Dec 25, 2003 | 06:22 AM
jonyb's Avatar
Default Re: Cams for turbo setup on B20/P73. ECU suggestions. Your opinions please (NVturbo)
Anybody else??? How about the skunk2 turbo cams?
wfocrx
27
Sep 7, 2015 08:53 AM
K_pem
Jul 2, 2011 07:45 AM
b20turbocivic
Apr 18, 2007 09:46 AM
Garage 808 Hatch
Sep 9, 2006 11:02 PM
jonyb
Dec 26, 2003 01:37 AM
