where does this go (please take time to look
Old Dec 23, 2003 | 06:33 PM
t3to4e's Avatar
Default where does this go (please take time to look
on the back of my gsr that im putting in my odb1 ls there is a coolant line closest to the water pump and it is a rubber hose that goes into a metal hose that hooks onto the intake manifold bracket then goes all the way under the throttle body where does this line go to im confused
Old Dec 23, 2003 | 06:47 PM
t3to4e's Avatar
Default Re: where does this go (please take time to look (t3to4e)
also i have a coolant line coming off the fire wall its right next to the longer one that goes to the side of the head
Old Dec 23, 2003 | 11:11 PM
martini's Avatar
I don't really understand what you are talking about. pics perhaps?
Are you talking about the throttle body coolant hoses?
Old Dec 24, 2003 | 07:10 AM
BeerMan's Avatar
Default Re: where does this go (martini)
gonna need some visual aid on this one
Old Dec 24, 2003 | 08:17 AM
mattssi's Avatar
Default Re: where does this go (t3to4e)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t3to4e &raquo;</TD></TR><TR><TD CLASS="quote">also i have a coolant line coming off the fire wall its right next to the longer one that goes to the side of the head</TD></TR></TABLE>
I believe that you are referring to the heater core lines there! On the other lines you speak of there, I think you may be talking about IAC lines! It goes like this! One line from the thermostat housing tube(leads to water pump) goes to the iac, then the other line from the iac goes to the iacv (attached to throttyle body on gsr's)Then the other line from that goes to the thermostat housing next to the actual thermostat! As far as the lines from the heater core! That is really simple! One goes to the pass side of the head, and the other attaches on the backside!
Old Dec 24, 2003 | 08:40 AM
IN VTEC's Avatar
Old Dec 24, 2003 | 10:53 AM
XSSIVE's Avatar
Default Re: where does this go (IN VTEC)
Ben to the rescue...i was just about to post that for you..
-Mike
Old Dec 24, 2003 | 10:56 AM
mattssi's Avatar
That explains it much better than i could, Good job guys!
95CoupeDX
Feb 5, 2008 06:54 AM
egerdahl
May 27, 2006 12:04 AM
done
Oct 14, 2005 12:24 PM
adictionbass
Jan 18, 2005 01:53 PM
igo4bmx
Apr 8, 2004 07:25 PM
