APEX VTEC CONTROLLER PROBS
Old Dec 23, 2003 | 05:15 PM
crxsi26's Avatar
Default APEX VTEC CONTROLLER PROBS
HI! I RECENTLY INSTALLED AN APEX VTEC CONTROLLER ON MY 89 CRXSI. THE PROBLEM IS IT DOSNT READ THE RPM'S. IF ANYONE HAS AN OPINION ON WHAT THE PROBLEM COULD BE, I WOULD APRRECIATE IT
Old Dec 23, 2003 | 06:09 PM
C8V6C's Avatar
Default Re: APEX VTEC CONTROLLER PROBS (crxsi26)
I had a bad solder by the shop that helped me with my swap. It was the vtec signal comin from the ecu, and the reason why I knew it was this was, after a while, my vtec controller stopped reading my vtec on the menu. Played with some wires and squeezed a few wires electrical taped together. Opened it up, and the wire was nearly comin off and was probably draing my battery cuz for some reason, my ecu stays on even with the car off. Soldered back together, and I'm happy to say that I haven't had any start probs for about a week.
Old Dec 23, 2003 | 06:12 PM
C8V6C's Avatar
Default Re: APEX VTEC CONTROLLER PROBS (C8V6C)
I'd first make sure the wire was in the ecu securely, and then watch the rpm guage on the vtec controller and play with wires. It worked for me
Old Dec 23, 2003 | 08:35 PM
mastarolla's Avatar
there should be a wire spliced to the ignition signal on the ECU....check this splice because that is the signal wire to read RPM, if everything is cool then something may be wrong with the harness...
Old Dec 23, 2003 | 10:08 PM
C8V6C's Avatar
Default Re: APEX VTEC CONTROLLER PROBS (mastarolla)
Yeah, that wire was f* on mine, but I was able to squeeze it together to make it touch again. The wiring should be illustrated in the manual If you didn't install yourself.
Old Dec 24, 2003 | 11:12 AM
crxsi26's Avatar
THANKS GUYS! IT WAS A LOOSE CONNECTION ON THE RPM WIRE. ALL IS WELL!
Old Dec 24, 2003 | 11:18 AM
Kendall's Avatar
Easy with the caps lock, it's considered rude.
Old Dec 24, 2003 | 02:18 PM
C8V6C's Avatar
Default Re: (dc231)
lol, does this happen with a lot of people? It happened to me, this guy,.......
Old Dec 24, 2003 | 03:43 PM
mastarolla's Avatar
Default Re: (C8V6C)
solder the connections for peace of mind
Old Dec 26, 2003 | 04:17 PM
crxsi26's Avatar
HEY GUYS ! SORRY ABOUT THE CAPS BUT MY EYES DONT LIKE THE SMALL PRINT! SO PLEASE DONT BE OFFENDED!
812mja
Sep 2, 2013 05:26 AM
jetoutant
11
Jan 2, 2008 07:50 PM
05 S2K Stoner
Oct 28, 2004 06:40 AM
